Old 11-05-2012, 05:00 PM   #1
1977 Argosy 24
Milltown , Wisconsin
How many amps at 12 volt?
If I use a 115 volt 23 watt compact florescent light with an inverter from a 12 volt battery, how many amps will it draw and how long will it run on a 625 amp 12 volt battery?
ventport is offline   Reply With Quote
Old 11-05-2012, 05:20 PM   #2
rodsterinfl's Avatar
2006 25' Safari
St. Augustine , Florida
Images: 8
I = (23 W /115 V) = 0.2 amps.
That 625 amps is probably cold cranking power - 30 seconds of power. The reserve power of the battery is more specific to what you want to know. That is harder to figure. A 106 amp hour battery would run your .2 amp light for about 22 days or over 500 hours I believe.
This does not account for any loss in the inversion of power.
Old 11-05-2012, 05:39 PM   #3
1977 Argosy 24
But doesn't the amps change when you drop the voltage to 12 volts, or doesn't that apply since I am using an inverter to change 12 volts to 115 volts?
Old 11-05-2012, 05:44 PM   #4
drboyd's Avatar
1978 25' Tradewind
Metro Phoenix , Arizona
23 watts is just a hair under 2 amps at 12 volts. Given the inefficiency of your inverter, 3 amps would be a safe guess.
Old 11-05-2012, 07:28 PM   #5
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
This might sound dumb, but why not simply get a 12 volt fluorescent fixture? Usually, a two tube light is 16 watts, with no loss, and no Rube Goldberg 12 volt to 120 volt to fluorescent tube setup.
Old 11-05-2012, 07:29 PM   #6
MaxTow's Avatar
2005 30' Safari
Kanata , Ontario
3 amps from +12v is a good estimate. I've not looked at the efficiency of invertors, but I would be surprised if they are better than 75% efficient.
This means to get 23W out, you need to put 30.6W in. If the battery voltage as measured at the input of the invertor is +12v then it draws 2.6A.
To answer your question, you need to know the capacity of the battery - this is measured in amp-hours. i.e. how many amps for how many hours.
MaxTow is offline   Reply With Quote
Old 11-05-2012, 07:33 PM   #7
TouringDan's Avatar
1966 24' Tradewind
1995 34' Excella
Lynchburg , Virginia
I would use 2.5 amps as a realistic current flow. For a 106 amp-hr battery, you don't want to drop the voltage below 50% of the rating, so I would say that you could operate the 23 watt light for about 20 hrs (53/2.5).
Dan
Old 11-06-2012, 06:14 AM   #8
1977 Argosy 24
Thanks for the info. A 12 volt fluorescent fixture would be a better bet. I just wanted to use a table lamp outside using an extra battery I have.
12 volt
