Old 08-09-2010, 05:55 PM   #1
tksbaskets's Avatar
2007 25' Safari FB SE
Dexer , Michigan
How do we replace ceiling lights in a 2007 Safari SE?
Hello,
There must be an easy way to replace the canister lights in the ceiling fixtures. These lights are pretty much flush with the ceiling. What is the trick to getting the bulb out? All I managed to do was push a bulb in a bit
I'm hoping someone can help me out.
Here is a picture:
tksbaskets is offline   Reply With Quote
Old 08-09-2010, 07:25 PM   #2
SilverGate's Avatar
2007 23' Safari SE
San Diego , California
Here's how we did it. ( Post # 106 of the LED Lighting retrofit for interior lights thread)
On this page 8 of the above thread. LED lighting retrofit for interior lights
SilverGate is offline   Reply With Quote
Old 08-09-2010, 07:39 PM   #3
tksbaskets's Avatar
Dexer , Michigan
Thank you Silvergate. This looks like more than we are wanting to do. We just want to replace the bulb.
Teresa
Old 08-09-2010, 07:47 PM   #4
SilverGate's Avatar
2007 23' Safari SE
Yes, but to get to the light bulb requires the same technique.
Here's the pertinent quote from the posting that I was trying to link:
"As shown, the inner metal ring containing the glass lens is pried loose and partially out, with difficulty using the finger nails (to avoid scratches on the metal), and then easily pried out using a flat blade screwdriver.
Once the LED is installed, the 2 wide opposing slots (see photo of lens rim on black pillow) in the rim tabs of the inner metal ring must match up and fit over the 2 fixture support bars (seen in bottom left photo at 7:00 of the rim space) to allow the metal rim to be matched and pushed back into the fixture."
Note to moderators: Is there currently a problem with the forum's ability to make correct links?
Old 08-09-2010, 08:05 PM   #5
tksbaskets's Avatar
Dexer , Michigan
Just came back from the barn and this worked!!! Thank you so much I used my Creative Memories plastic letter position-er (I call it the artificial finger nail) and narry a mark on the ceiling.
One light that I though was burned out magically turned on when I unsnapped the ring.
I really appreciate the quick replies SilverGate.
Teresa
Old 08-09-2010, 09:30 PM   #6
SilverGate's Avatar
2007 23' Safari SE
You're very welcome, Teresa!
Thank you for saying "Thank you"... not everyone who inquires here and who gets an answer has the courtesy of saying "Thank you" in return!
Old 01-06-2013, 08:50 PM   #7
Ronman's Avatar
2007 27' Safari FB SE
Rancho Murieta , California
I am late to this party but want to pick the BRAINS of the AS Forum. Is there a source to replace these halogens with halogens? My wife has found papers on the potential cancer causing properties of LED. ( WHO KNOWS!) But "She Who Must Be Obeyed" prefers halogen. Anyone??
Thank you!
Ron
Ronman is offline   Reply With Quote
'Puck' Lights in Ceiling of a 28 SE Cstar Lights - Interior & Exterior 1 10-19-2009 10:35 PM
What did you do for ceiling lights? malconium Lights - Interior & Exterior 12 07-09-2008 12:39 PM
Ceiling lights niftypkg Lights - Interior & Exterior 4 03-04-2007 05:01 PM
Round ceiling lights TroutStream General Interior Topics 23 05-09-2006 10:25 AM
how to remove ceiling lights NewStreamer General Interior Topics 18 02-01-2003 04:41 PM
