Old 01-09-2016, 06:10 PM   #1
Mrmill's Avatar
2016 30' International
2015 25' FB Flying Cloud
Paso Robles , California
How do I remove the LED clearance lights?
I have a 2016 30' International Serenity and I'm installing a rear view camera. The problem I have is that the lens cover for the rooftop clearance light doesn't appear to be easily removed. It looks like the LED guts are molded into the lens. Anyone out there done this before or have any knowledge to share?
Thanks.
Mrmill is offline   Reply With Quote
Old 01-09-2016, 06:42 PM   #2
2016 30' Classic
Erie , Colorado
Slip a small flat blade screwdriver between the plastic light and the chrome mount at one end, I usually do the narrow end first, and gently pry up. It is held in place with a spring clamp. Search the forums and you can probably find a photo. Sea ch my user for Voyager camera.
Gary
2015 Classic
2015 GMC Sierra 2500HD Duramax
ProPride
NŘVPN
ghaynes755 is offline   Reply With Quote
Old 01-09-2016, 06:53 PM   #3
Eugene , Oregon
The light lens, if it is like our 2015 FC which I bet it is, unclips at the two ends. I used a hard plastic pan scraper used for cleaning (like a credit card) to gently but firmly pry the lens with its attached clips away from the Airstream body. Search under "rear view camera airstream" and perhaps someone has posted a photo. Could also just search under "removing light lens on Airstream" or some such wording. It was unnerving as these things sometimes are and then once off is so obvious. I removed our light lens when installing our Voyager rear view camera.
Meeks is offline   Reply With Quote
Old 01-09-2016, 07:04 PM   #4
Mrmill's Avatar
Thank you very much. I'll give that a try tomorrow. Appreciate the advice!
Old 01-10-2016, 12:28 PM   #5
DeltaRon's Avatar
2015 28' Flying Cloud
Cumming , Georgia
Clearance light pic
Here's a pic from my 2015 FC 28
DeltaRon is offline   Reply With Quote
Old 01-10-2016, 02:21 PM   #6
DeltaRon's Avatar
Cumming , Georgia
Pic re-try
Last try for pic
Old 01-10-2016, 02:48 PM   #7
Mrmill's Avatar
That picture is helpful! Thank you!
Old 05-06-2016, 12:36 PM   #8
2016 27' Flying Cloud
Steamboat Springs , Colorado
Hey Delta Ron -
Do you have a photo of the final installation of the rear observation camera? I am going to install a Voyager Digital Wireless System WVOS541 system. Did you attach the mounting bracket of the camera with screws or just the double back tape and sealant around the bracket? I was thinking of maybe a small aluminum backup plate between the Voyager bracket and the Airstream Skin. Any in for regarding your installation and hook up to the running lights would be appreciated. Thanks, Jerry
StreamBean is offline   Reply With Quote
A good deal LED clearance lights! Anon Lights - Interior & Exterior 13 10-17-2013 10:39 PM
Remove riveted clearance/marker lights - '68 Sovereign BuffaloJoe Lights - Interior & Exterior 0 06-21-2013 09:05 PM
Question about LED clearance lights drlora Lights - Interior & Exterior 9 08-13-2010 08:33 AM
Found a better source for LED clearance lights! Anon Lights - Interior & Exterior 8 08-05-2007 07:07 PM
LED Clearance/Marker lights Safari Tim Lights - Interior & Exterior 13 10-24-2003 09:54 PM
