Old 06-12-2014, 04:13 AM   #1
captmatt's Avatar
1986 31' Sovereign
Naples , Florida
How do I check fuses?
This is the first time I've seen a 12v fuse panel like this. I was hoping to check fuses with multimeter by checking across the brass connectors but no reading. How do you check these fuses?
Name:	ImageUploadedByAirstream Forums1402567912.886939.jpg
ID:	214089Click image for larger version
Name:	ImageUploadedByAirstream Forums1402567946.965848.jpg
So where is the hiking trail?
captmatt is offline   Reply With Quote
Old 06-12-2014, 04:18 AM   #2
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
I do not believe that is a fuse panel. That looks like a bus bar.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 06-12-2014, 04:29 AM   #3
captmatt's Avatar
1986 31' Sovereign
Naples , Florida
Interesting. Door is labeled fuse panel and door lists the amperage of corresponding fuses. But it does look like a bus bar (with small black plastic boxes behind it). Very confusing, lost porch lights and stereo, seems to be fuse related...
Old 06-12-2014, 04:54 AM   #4
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
Those are automotive type breakers, not fuses, connected to the copper/brass bus bar. You can check for continuity between the two lugs with your multi-meter. Some of them might have a button that extends if they trip from overload. If they do not have a button, they are designed to re-set on their own as the circuit cools after tripping.
If there is no button and no continuity, you will need to replace the breaker.
add edit: If you have to replace a breaker, disconnect the battery ground cable and unplug shore power. I found out from experience, with a lose (+) wire it's easy to burn a hole in aluminum!
add edit 2: I bought replacement breakers at ODM, but you can get these at your local auto parts store.
Alan
Old 06-12-2014, 05:09 AM   #5
richinny's Avatar
2011 34' Classic
they are 12v breakers and the little white buttons on the far right are pushed in to reset the breaker.
Ricky
Old 06-12-2014, 05:39 AM   #6
1988 25' Excella
Trumbull , Connecticut
Auto Reset Breakers
Hello fellow Streamers. I have the same fuse panel in my 88 Excella. People are correct, they are auto reseting circuit breakers. They can be tested with a meter be measuring from ground to each side of the breaker and it should read the same voltage, as there is negligable voltage drop across a short. If the breaker was bad and stuck open, measuring from ground to the buss side would read the 12 VDC or so and the other side of the breaker would read close to 0 VDC.
Good luck
Happy camping nm1oqrz
nm1oqrz is offline   Reply With Quote
Old 06-12-2014, 06:06 AM   #7
captmatt's Avatar
1986 31' Sovereign
Naples , Florida
Thanks! I was so frustrated by this panel I was ready to just do without tunes in the trailer. I appreciate all the responses !
Old 06-27-2014, 05:50 PM   #8
Scotman's Avatar
1986 25' Sovereign
Lake Alfred , Florida
I have the same panel and was just as confused by it. This thread helped clear it up!
Scotman is offline   Reply With Quote
Old 07-30-2014, 08:28 PM   #9
captmatt's Avatar
1986 31' Sovereign
Naples , Florida
Never found what the problem was, so I took AS to area dealer that now deals w/AS. I was ready for the ROASTING i got from the last RV Dealer but they said it was just a connection problem...( I read as a little corrosion.) Any way, problem solved. Picking it up tomorrow. No mention of charges, so I'm hoping it will be just the 145.00 I agreed to. If I'm happy I will post the name of the dealer. If I'm NOT happy I may post the name of the dealer a lot!?
Old 07-30-2014, 08:48 PM   #10
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Hey, finding problems can be challenging. Hopefully it was just cleaning up a bad connection.
I bet there are a few AStreamers in your area who might look at problems with you.
Peace and Blessings..
Channing
WBCCI# 30676
Old 08-01-2014, 12:06 PM   #11
captmatt's Avatar
1986 31' Sovereign
Naples , Florida
Loose wire nut on new radio... I could have fixed it with my eyes closed, if I ever found it! To make it interesting the Tech left a light on in the trailer to confirm all was well and forgot to turn it off. drained battery DEAD! Jose, our serv. rep. found a portable jumping unit and helped us get everything together since the trailer jack was no help with no power. Even helped with small refrigerator issue I had, no charge. Overall, very happy! I will go back to NorthTrail RV in Fort Meyers (not to be confused with business on East coast of FL with similar name). For repairs or maybe a newer unit some day... I'll ask for Jose!
Old 08-01-2014, 12:53 PM   #12
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
I would think they would solder connections rather than use wire nuts-
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 08-07-2014, 06:39 AM   #13
Skater's Avatar
1995 30' Excella
Bowie , Maryland
Wire nuts on a 12 volt wiring circuit? Not really the best solution. Of course, Airstream did the same in mine for the marker lights...
1995 Airstream Classic 30' Excella 1000
2014 Ram 2500 Crew Cab with Cummins 6.7L Diesel
Sold but not forgotten: 1991 Airstream B190
Sold: 2006 F-250 6.0L Powerstroke Supercab
Skater is offline   Reply With Quote
Old 08-08-2014, 05:30 PM   #14
captmatt's Avatar
1986 31' Sovereign
Naples , Florida
Wire nuts are only as good as the wirenut that is assembling the sound system...
40 amp fuses for Univolt java71 Electrical - Systems, Generators, Batteries & Solar 9 06-24-2005 04:31 AM
40A Fuses? 66Overlander Electrical - Systems, Generators, Batteries & Solar 2 04-22-2004 08:07 PM
replacing glass fuses with blades maznblu Electrical - Systems, Generators, Batteries & Solar 4 08-05-2003 11:34 PM
12 volt fuses jim clydesdale Electrical - Systems, Generators, Batteries & Solar 2 03-18-2003 05:47 PM
Check , Check and Re-Check a new refer saga. thenewkid64 Refrigerators 13 06-24-2002 09:54 AM
