Old 08-17-2011, 05:49 PM   #1
Alumaholic's Avatar
1966 24' Tradewind
Albuquerque , New Mexico
Images: 33
How Do I Change a Light Bulb...
... In the little, 12-volt, swivel, reading lamps in a 2007 Classic 30'?
(P.S. I have completely restored two vintage Airstreams, burped fridges, replaced Univolts, polished a 31' Sovereign, and other technically challenging tasks; but I can't change these danged light bulbs. Be gentle with me.)
Ken L
1966 Tradewind 24
2007Chevy Silverado 2500 HD Duramax/Allison
Four Corners Unit WBCCI #8654
Alumaholic is offline   Reply With Quote
Old 08-17-2011, 06:35 PM   #2
Silver Goose's Avatar
2008 27' Classic FB
Burkburnett , Texas
If they are like the ones in my '08 Classic, there is a frosted glass lens surrounded by a metal bezel. This is simply pressed into the housing. On mine there is a thin black plastic ring that separates the front bezel from the body. Use your fingernail, or nothing that will mar the finish and separate the bezel from the ring. Once it starts to come loose pull it off. The bulb has 2 pins, so just pull the bulb straight out.
AIR 47751
Air Safe Hitch, Reese Dual Cam 800#, Centramatics
Silver Goose is offline   Reply With Quote
Old 08-17-2011, 09:17 PM   #3
Alumaholic's Avatar
1966 24' Tradewind
Images: 33
I Know, I Know...
... you let a psychiatrist do it, but it has to want to change.
Ken L
1966 Tradewind 24
Old 08-18-2011, 12:24 AM   #4
BIGED52's Avatar
1967 22' Safari
MILAN , Illinois
Ken, There should be a section in your owners manual on lighting that covers replacing bulbs. But as suggested above separate the bezel/lens cover from the housing and pull the old bulb straight out. Ed
1967 Safari Twin "Landshark" w/International trim package
1999 GMC Sierra 1500 SLT
FORUMS MEMBER SINCE 12/16/2004AIR#7110
"My tire was thumping, I thought it was flat. When I looked at the tire, I noticed your CAT!" Burma Shave
BIGED52 is offline   Reply With Quote
Old 08-18-2011, 09:07 AM   #5
Wise Elder
Jammer's Avatar
2010 30' Classic
Ken
Airstream changed the reading lights from year to year but they are all difficult to open. It might be helpful for you to post a pic so we can see what you have.
On mine the glass lens has to be pried out of the housing where it is tightly fitted. When the time comes I will be surprised if I can do this without damaging the housing or breaking the glass. It may be easier to buy new lights.
Old 08-18-2011, 10:17 AM   #6
1967 22' Safari
South East Idaho , South East Idaho
PLyers?
Grad67 is offline   Reply With Quote
Old 08-18-2011, 11:17 AM   #7
Alumaholic's Avatar
1966 24' Tradewind
Images: 33
Yankee Doodle Had it Right...
... a very, very thin pry tool between lense and bezel did the trick.
Ken L
1966 Tradewind 24
LED light kit for the Monarch stop tail and turn light Dan@LED4RV Commercial Listings 5 05-12-2014 05:05 AM
LED Replacement for the 1383 bulb Dan@LED4RV Commercial Listings 5 06-22-2011 06:25 PM
first ceiling light Segue Lights - Interior & Exterior 2 05-14-2011 01:18 PM
New Light for the cedar closet Dan@LED4RV Commercial Listings 6 04-07-2011 07:04 PM
Regular style light bulb that works off of 12 volts Dan@LED4RV Commercial Listings 0 03-24-2011 12:49 PM
