Old 01-27-2015, 06:44 PM   #1
goshawks00's Avatar
1966 22' Safari
1954 22' Flying Cloud
Saline , Michigan
High lumen LED for E-26
I am replacing my sconce lights with 12v dc LED. What are you all using for high lumen lights that are a direct fit into E-26 fixtures?
goshawks00 is offline   Reply With Quote
Old 01-28-2015, 10:56 AM   #2
goshawks00's Avatar
1966 22' Safari
Saline , Michigan
Has no one converted to 12v LED and used the original 110 fixtures? Those are known as E26 fixtures. If so what bulbs are you using? Do you know the brightness (lumens) of the bulbs you are using?
Old 01-28-2015, 11:19 AM   #3
Thalweg's Avatar
1962 24' Tradewind
Buffalo , Wyoming
I used these:
iLLumi Projections WARM WHITE 42x 5050 cluster E26 Screw Base DC 12V-20V 9W Motor Home Marine Low Voltage LED Light Bulb DC battery Solar fishing lamp FREE SHIPPING - Led Household Light Bulbs - Amazon.com
My electrical system is a little older than yours though. I have dedicated 12-volt lights and separate 110-volt lights. So I'm not sure if this is what you need.
Thalweg is offline   Reply With Quote
Old 01-28-2015, 04:31 PM   #4
goshawks00's Avatar
1966 22' Safari
Saline , Michigan
My system is new and it's all wired for 12v. Because these lights will be inside wall sconces I am already restricting the light path, that's the reason I am looking for high lumen 12v bulbs. I see they say " equivalent to a 75 watt bulb but never come out and say what the lumens are. I am glad however to see that they are at least available for testing. I also found a bulb that is 'advertised' as equal to a 150 w. bulb. Thanks for the link...
Old 01-28-2015, 06:06 PM   #5
Thalweg's Avatar
1962 24' Tradewind
Buffalo , Wyoming
I could take a picture of mine with the lights on if that would be of help. I don't have a way of measuring the light output though. Unfortunately, I'm out of town right now and won't be home until Saturday.
Old 01-28-2015, 06:32 PM   #6
goshawks00's Avatar
1966 22' Safari
Saline , Michigan
If you think of it that would be great , thank you!
hydraulic leveler question - how high is too high? JourneytoRet Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 12 04-06-2013 11:33 AM
Gas Prices for 2011 - How high is too high to tow? Kosm1o On The Road... 77 01-02-2011 09:48 PM
Clipper, Hella LED, Design Line Hella, LED Kit, Stop/turn LED masseyfarm Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 1 12-15-2010 11:03 AM
