Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar > Lights - Interior & Exterior
Old 09-23-2015, 05:03 PM   #1
Rivet Puller
SeeMore's Avatar
2003 28' Safari S/O
Atlanta Burbs , Georgia
Hidden high voltage junction boxes in slide out models
If you ever discover a dead outlet under the table in a slide-out model this picture should help tremendously in resolving your issue.
My wiring diagram showed one junction box in the curbside wire routing to the slide-out wall outlet, but the reality was there were two curbside! One under the cabinet beside the refrigerator and one hidden behind a removable panel in the right side dinette frame. My issue was easily resolved upon discovering the wire nut had vibrated loose on one lead.
I hope this adds knowledge to others
Name:	Empty Slideout.jpg
SeeMore is offline   Reply With Quote
Replacing Carpet in Slide Out Models jchodgdon Floor Finishes 8 01-19-2021 03:51 AM
Too High Battery Voltage? TankerIP Batteries, Univolts, Converters & Inverters 14 08-08-2010 08:58 PM
High Voltage in Mexico cooney Electrical - Systems, Generators, Batteries & Solar 2 12-19-2008 06:01 PM
High Voltage Power lines and batteries safari57 Batteries, Univolts, Converters & Inverters 9 10-31-2006 10:31 PM
High Voltage kooblekidz Mechanics Corner - Engines, Transmission & More... 8 02-05-2004 07:32 PM
