Old 04-08-2015, 02:06 PM   #1
dznf0g's Avatar
Oswego , Illinois
Here's a weird one, but it is what it is
At the end of last season I installed a brighter LED pad light with an 1156 base in the shower overhead fixture. I just noticed that whenever I turn on the shower light, I lose all over the air digital signals on the TV.
Doesn't lose signals with the old LED cluster bulb nor an incandescent bulb. Must be some noise generated on the 12v circuit?????
-Rich-
Old 04-08-2015, 02:11 PM   #2
2007 22' International CCD
Yep. Probably generates some noise and messes with the TV amplifier. Try a different LED?
Old 04-08-2015, 02:12 PM   #3
Belegedhel's Avatar
1973 21' Globetrotter
Houston , Texas
My guess is that you have a loose connection or noisy switch that is spewing out EMR. In my house, if I operate the ice dispenser on my fridge, it knocks out the digital TV signal as well.
Old 04-08-2015, 02:15 PM   #4
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Our MW also took out all 802 signal in our home till I reoriented the antennas
Peace and Blessings..
Channing
WBCCI# 30676
Old 04-08-2015, 02:17 PM   #5
dznf0g's Avatar
Oswego , Illinois
As I said in the 1st post.....works fine with an LED cluster bulb and with an 1156 incandescent. Just knocks out the signal with the "pad" LED with an 1156 base pigtail. That eliminates the circuit or switch from having an issue. It is consistently repeatable.
-Rich-
Old 04-08-2015, 02:25 PM   #6
Lost in America
mojo's Avatar
2015 27' FB International
2004 19' International CCD
Santa Fe , New Mexico
Your Faraday Cage is possessed!
This is the strangest life I've ever known - J. Morrison
2015 Airstream International Serenity 27FB
2017
Chevy Silverado 2500HD Duramax Diesel
mojo is offline   Reply With Quote
Old 04-08-2015, 02:27 PM   #7
dznf0g's Avatar
Oswego , Illinois
True dat!
-Rich-
Old 04-08-2015, 03:31 PM   #8
Sometimes a largish ferrite core with the supply and ground leads wrapped through it a few times can help. Available at Radio Shack, assuming there is one still open in your area.
Old 04-08-2015, 03:38 PM   #9
dznf0g's Avatar
Oswego , Illinois
Not a biggie, I'll just shower with the more dim 1156 LED bulb....nothing there I want to see anyway!
-Rich-
Old 04-08-2015, 05:46 PM   #10
TMI.....😁
Old 04-08-2015, 05:57 PM   #11
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Just leave the lights off!!! Sorry!
Old 04-09-2015, 08:13 AM   #12
richw46's Avatar
Lexington , Kentucky
I found an interesting article on this. They point to cheaper LED bulbs as one culprit. The other is TV wire shielding. Two possible fixes:
1. Buy a different brand of LED bulb (just 1) and try that in the socket causing the problem
2. Try quad-shielded coax on the TV cable.
The Digital RVer: Does LED lighting put your RV TV on the fritz?
-Rich
Rich & Yvonne
2006 Safari SE -Dora-
2004 4Runner SE
richw46 is offline   Reply With Quote
Old 04-09-2015, 09:19 AM   #13
SteveH's Avatar
Common Sense , Texas
It's the LED's. I have some in my Casita that will do the same thing. The later and supposedly better quality ones I bought do not effect the TV.
Regards,
Steve
Old 04-09-2015, 04:30 PM   #14
1983 31' Excella
The Woodlands , Texas
I bought my bulbs from M4 Products . I have not had any problems with them.
Air83 is offline   Reply With Quote
I am sure there is another old post around here about this, but... Hobie1 Forum Admin, News and Member Account Info 2 08-09-2011 10:09 AM
Why do these get posted here but I can not find the Airstreams on E Bay? macofpei Airstreams on eBay 0 03-13-2010 03:57 PM
We don't have a trailer YET, but here I am. airstreampilot Member Introductions 4 08-19-2009 04:50 PM
OK, Here's a weird water pressure problem mello mike Fresh Water Systems 8 01-08-2006 02:34 PM
Never seen one...but I want one! pillageTHENburn Airstream Motorhome Forums 18 10-08-2004 01:38 PM
