Old 11-08-2010, 06:39 PM   #1
theduncan's Avatar
1977 31' Excella 500
blanchard , Oklahoma
Help with brake light / blinkers please...
When connected to the tv, none of the lights work properly. The brake lights don't work at all, and both sides flash (like hazard lights) when either blinker is on. They also do not come on with headlights, for night driving.
Any help is appreciated!
theduncan is offline   Reply With Quote
Old 11-08-2010, 06:59 PM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
If you have a 7 pin connector and a battery in the trailer you can use this diagram to test things out.
Electrical Tips
If you have a test light or volt meter test for voltage between 1 and 7 o clock. If you have voltage your trailer battery system is good. If that is the case now using the front view of the connector place a short section of #12 wire in the battery slot, at 1 o clock, and then touch the other end of the wire to the parking lights and see if they come on. Do the same with the left and right signal lights, 3 and 9 o clock. If the lights work with this test your problem in in the TV wiring.
If you have voltage from the battery and these tests do not produce lights in each test you have a wiring or ground problem in the trailer itself. Check the grounds at each fixture first as that is the common point of failure.
If the grounds are good you will have place the test wire in a circuit and test for voltage working your way back to the fixture at points of connection. First point would be just inside the trailer where the umbilical cord is connected to the trailer wiring and then at the fixture itself.
2004 Excursion 4x4
Old 11-08-2010, 07:04 PM   #3
theduncan's Avatar
Will try. thanks!!!
More brake light problems azfiredog300 Lights - Interior & Exterior 14 06-29-2010 01:27 PM
brake controller light is always on nomader Brakes & Brake Controllers 5 03-04-2010 11:21 PM
Brake warning light tandemfish Mechanics Corner - Engines, Transmission & More... 3 04-25-2006 07:04 PM
Brake Light fuse keeps blowing BW_LandYacht36MH Land Yacht/Legacy Motorhomes 3 08-25-2005 12:25 PM
Brake light socket needs to be replaced Argoman All Argosy Trailers 5 09-16-2004 12:49 PM
