Old 01-13-2012, 01:11 PM   #1
Air-Texas's Avatar
2004 34' Classic S/O
Stafford , Virginia
Help to Install new teardrop LED marker lights
OK, I searched, but could not find a install of new from Airstream 2 wire teardrop led marker lights.
Do the old 2004 classic marker lights have 2 wires?
Will I need to drill out rivets to remove the old lights?
The new LEDs have a foam base, will I still need to add sealer under the foam?
Mike, Miho &
S/OS#069
TAC # TX-33
WBCCI #5702
"Eva" 2004 Classic Limited 34' S/O
"Wall-E" 2012 Ford F250 King Ranch
Air-Texas is offline   Reply With Quote
Old 01-13-2012, 01:34 PM   #2
10Smiles's Avatar
2005 30' Classic
Kingston , Washington
Could you please post a picture or link to the new lights?
Thanks.
10Smiles is offline   Reply With Quote
Old 01-13-2012, 01:45 PM   #3
Air-Texas's Avatar
Stafford , Virginia
Mike, Miho &
S/OS#069
TAC # TX-33
WBCCI #5702
Old 01-13-2012, 01:58 PM   #4
vinstream's Avatar
1962 19' Globetrotter
1963 19' Globetrotter
1961 19' Globetrotter
Wheat Ridge , Colorado
You will need to drill out pop rivets that hold the lights on in most cases.... Sometimes they are screwed into place and the screws will be very rusty and hard to get out so you may have to break them off...
As far as the wiring part of your question, there will either be two wires or one. In the case of one, the black or "hot" wire will connect to the one wire and the white or "neutral" wire will connect to the trailer frame. Note: make sure you get a good grounding to the frame. If there are two wires then connect the two wires. The black should also be hot in this case too! Hope that helps! Bright lights!
www.VINSTREAM.com
Wheat Ridge, Colorado
WBCCI # 1962
Instagram #Vinstream
vinstream is offline   Reply With Quote
Old 01-13-2012, 02:03 PM   #5
Air-Texas's Avatar
Stafford , Virginia
Still need to know about using the sealer under the foam....
Mike, Miho &
S/OS#069
TAC # TX-33
WBCCI #5702
Old 01-13-2012, 02:13 PM   #6
Dan@LED4RV's Avatar
Denton , North Carolina
two wire
Any time you have a two wire light you want to use on an Airstream you have to make up your own eye-let to serve as a ground. Below is a picture of a light that comes from the factory this way.
You will need to get an eye-let, trim and splice your neg(-) wire then put the eye-let on that wire. When you mount your new light include the eye-let so you will complete the circuit. The one single wire on your new light (coming out of the bottom of your light) will attach to the wire coming out of the body of the trailer.
You will need to drill out the rivet to get the old light out.
And you will need to use sealer.
Dan Brown
Denton NC
Dan@LED4RV is offline   Reply With Quote
Old 01-14-2012, 07:58 AM   #7
3 Dog Nite's Avatar
1989 34.5' Airstream 345
Cleveland , Tennessee
Yes indeed, I agree. I used only the sealer & threw the foam pad away.
Ricky
"Sometimes I wonder if the world is being run by smart people who are putting us on, or by imbeciles who really mean it." Mark Twain
AIR 22749 WBCCI 2349 NOVA TAC TN-6
1989 345 LE Classic Motorhome
3 Dog Nite is offline   Reply With Quote
Old 02-03-2012, 06:05 PM   #8
NOAZRK
NOAZRK2690's Avatar
Kutztown , Pennsylvania
Air-Texas,
I can give you the straight scoop. No guess work. Switching over to LED tear drop clearance lights on a 2004 is fairly simple. All you will need is a wire cutter, phillips screwdriver, some extra wire, and some patients.
Here is my suggestion. Get some medium weight stranded wire and a good straight wire connector. Use the schrink type conector and make a water tight connection with a heat gun. Each light has two wires, a black and a white. It would be good to match the colors to avoid confusion.
1. Remove the old lense and base. Gently pry the base loose with a flat screwdriver or putty knife.
2. Gently pull the base away from the trailer body and pull about 2 inches of wire through the hole before you cut the wire. DO NOT LET THE WIRE DRAW BACK THROUGH THE HOLE!!! There is rubber type caulk on some of the wires that will act like a rubber band to pull the wires back between the walls. DON'T LET IT HAPPEN!!! Some of the lights will have plenty of extra wire between the walls, other lights will be a fight to get 1 1/2 inches to work with.
3. Put about a 4 inch pig tail on the existing wires that are too short for comfort.
4. Hook up your new lights, install a bead of caulk around the wire hole and the two screw holes.
5. Finish up with a bead of caulk around the base.
6 Removing the rear stop lights and back-up lights is really easy. Just remove the four lens screws remove the light bulb and put the new prewired light right into the existing light socket.
I strongly recommend saving your receipt for your new LED lights for the following reasons.
Bargman claims their LED lights last 100,000 hours. Two of my stop lights lasted about 50 hours then half the bulbs went out. Airstream only guarantees them for about 60 days, then you're stuck with them. I don't get it. You couldn't burn the lights 100,000 hours in 60 days if you wanted to. When I complained about the short bulb life at the factory parts store, I was told they only had 6 or 8 bad lights in years. I found it interesting that I got two of them and another AS Forum member got another one.
Having the LED lights is definately worth the hassle of installing them. It remains to be seen how many actual hours I will get out of each bulb.
Try doing a google search on line using Bargman LED lights RV.
~ALK
NOAZRK2690 is offline   Reply With Quote
Old 02-05-2012, 09:51 AM   #9
Air-Texas's Avatar
Stafford , Virginia
Thanks ALK!
Great post!
Mike, Miho &
S/OS#069
TAC # TX-33
WBCCI #5702
Old 03-15-2012, 03:41 PM   #10
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
"Yes indeed, I agree. I used only the sealer & threw the foam pad away."
Ricky
Two foam pads on the new teardrops?
"foam pad" goes under the lens, needed to keep the h2o out.
..... just replace the bulbs?,><whats the advantage of the whole assembly?
Name:	SEALING THE TEARDROPS 001.jpg
"Any nation that can survive what we have lately in the way of government, is on the high road to permanent glory."
Molly Ivins
"Just because you don't know how, doesn't mean you canít."
Amanamus
Sweet Streams....🌥
Old 03-17-2012, 11:42 AM   #11
Air-Texas's Avatar
Stafford , Virginia
Just to get the LED lights...looks cool!!
Mike, Miho &
S/OS#069
TAC # TX-33
WBCCI #5702
Old 03-17-2012, 11:50 AM   #12
Was thinking of changing, no ones just changing out the bulb's?
Seems like a lot cheaper way to go.
Especially if you've spent the time getting the tears from weeping & sealed properly.
Molly Ivins
Amanamus
Sweet Streams....🌥
Old 03-18-2012, 05:17 PM   #13
NOAZRK
NOAZRK2690's Avatar
Bob and All,
The replacement LED lights has a bulb that throws light to the front as well as in other directions. You won't get that look with just a bulb replacement. If your old base and gaskets are anything like mine were, it isn't worth the time to mess around with the old lights.
The biggest down fall that I see with a whole new LED light replacement is that you should really have one or two extra red and amber tear drops along with an extra two stop lights. If you get to your inspection station and a light isn't working, it's pretty doubtful that the shop will have an LED like you need.
In an earlier message I wrote about two of my LED stop lights burning out. Although Airstream would not stand good for my defective bulbs, I did get the number for the Barg Mfg. Co. and they replaced them for free. In fact, I called one day and they arrived in the mail the very next day. The customer service woman is a real sweet heart.
~ALK
Old 03-18-2012, 05:43 PM   #14
Spent too long getting them sealed, not about to remove them now.
I still have to rationalize the change to the exterior replacements that don't have any benefit other than looks. I know they are brighter...but its hard to miss a big silver tube with red and orange dots on it.
Have changed the step and porch along with interior with excellent results, definite improvement in looks and battery life...well worth it.
Plan to try a couple of these and see how they look in the teardrops.
Molly Ivins
Amanamus
Sweet Streams....🌥
Old 03-21-2012, 08:14 AM   #15
rodsterinfl's Avatar
2006 25' Safari
St. Augustine , Florida
Images: 8
Exactly Robert and all - why not just change the bulbs. There are wide dispersal LEDs. Red LED or Amber LED work well. The previous owner of my unit ordered an antenna and a marker light just before trading it in. I have them from Airstream in the package from his Jan 2012 order. The red teardrop has a white foam pad on the bottom and a black pad inside. They must have just changed the component. I plan on getting just the bulbs.
Old 03-21-2012, 08:34 AM   #16
Thumbs up
Originally Posted by rodsterinfl View Post
Exactly Robert - why not just change the bulbs. The previous owner of my unit ordered an antenna and a marker light just before trading it in. I have them from Airstream in the package from his Jan 2012 order. The red teardrop has a white foam pad on the bottom and a black pad inside. They must have just changed the component. I plan on getting just the bulbs.
Rod,
POI.. it's not apparent in the picture of the 1156 above but for better brightness you should match the color of the bulb too lens color.
Still... @ $17.95 ea. X 9 $161.55, it's hard to rationalize the change, after all, all your getting is a little brightness and longer life, thats a lot of 1156 incan's.
Haven't burned one out yet.
Molly Ivins
Amanamus
Sweet Streams....🌥
Old 03-21-2012, 10:37 AM   #17
2006 25' Safari
Images: 8
The red and amber LED 67 replacements are $2.99 each.
Old 03-21-2012, 10:40 AM   #18
snkrichards's Avatar
1978 23' Safari
eugene , Oregon
I wonder if someone would direct me on how to up load a photo in a reply. THanks
snkrichards is offline   Reply With Quote
Old 03-21-2012, 10:44 AM   #19
1978 23' Safari
eugene , Oregon
testing
i did it
Old 03-21-2012, 11:51 AM   #20
Thumbs up
Brain fart...thanks Rod.
even the 15 LED bulb is a lot less at $4.95.
Think I may just try a couple, just might be worth the 50 bucks.
Molly Ivins
Amanamus
Sweet Streams....🌥
Marker Lights how do you get to the wires? perryg114 Lights - Interior & Exterior 4 10-13-2011 08:51 PM
Marker Lights and License Plate Mount perryg114 Lights - Interior & Exterior 3 09-14-2011 09:04 PM
Dead marker lights MATTY J Lights - Interior & Exterior 10 05-29-2011 10:22 AM
LED interior lights: A complaint hampstead38 Lights - Interior & Exterior 0 03-23-2011 09:38 AM
Running Lights LED - How do I route the wire? AirHome Lights - Interior & Exterior 6 02-20-2011 08:15 PM
