Old 05-18-2019, 07:41 PM   #1
1976 Argosy 26
Pullman , Washington
Help on wiring external running lights
I am trying to fix a short in my running lights on my 1976 Argosy 28í. I repainted the trailer four years ago and replaced all the running lights in the process. The exiting wiring runs through a tiny hole in the trailer body that seems to be wearing away the plastic insulation and shorting on the metal surrounding the wire. I am trying to figure out how to insulate this wire through the whole without removing any interior of the trailer. I have posted a couple of pictures to show the wire. Any suggestions would appreciated Click image for larger version
ID:	341072Click image for larger version
hoopman77 is offline   Reply With Quote
Old 05-18-2019, 09:52 PM   #2
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Try sliding some heat shrink tubing over the wire.
Old 05-20-2019, 07:30 PM   #3
waninae39's Avatar
2017 22' Sport
NCR , Ontario
you can get rubber and plastic grommets and many big box stores in the electrical section
waninae39 is offline   Reply With Quote
No running lights, brake lights or trailer lights work from tow vehicle RichHog 1969 - 1973 Safari 42 05-02-2019 07:42 PM
Fridge External Fan running a lot.... leonot Refrigerators 23 07-20-2017 05:08 AM
Urgent Help....No Brake Lights when running lights are on Debnw Lights - Interior & Exterior 10 05-08-2015 03:04 PM
External Lights Wiring Caravel-61 Electrical - Systems, Generators, Batteries & Solar 1 06-08-2014 09:35 PM
Wiring tail & running lights JimC Electrical - Systems, Generators, Batteries & Solar 4 04-14-2003 12:38 PM
