Old 06-26-2011, 12:04 PM   #1
bassfiddler's Avatar
1971 23' Safari
Lilburn , Georgia
Help-Need tail light repair advice...
I need to repair an intermittent tail-light/blinker. The spring part at the bottom of the socket which keeps the lamps tight is shot and won't hold the lamp in place. What's the trick for getting this socket out without causing damage to the housing? Are the two rivets all that holds the housing in place? Anyone tackled this one yet?
[/IMG]
[/IMG]
bassfiddler is offline   Reply With Quote
Old 06-26-2011, 01:10 PM   #2
Change the cans out to LEDS and be done with the issue, as the other sockets will do the same thing.
Tail light and backup LED lights are available.
Old 06-26-2011, 01:57 PM   #3
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
You can drill out the rivets, and carefully pull the can out of the housing. You can feed the wires up through the hole in the housing, go to your local auto parts store, and get a new base insert, with wires and spring. It should cost less than $10.
Old 06-26-2011, 03:01 PM   #4
1971 23' Safari
Lilburn , Georgia
Yes, that's what I'm talking about. I would love to upgrade to LED eventually but for now need to improvise, adapt and overcome. I did get it apart and was thinking along those same lines...
Old 06-28-2011, 02:36 PM   #5
1971 23' Safari
Lilburn , Georgia
So...I installed a new socket and have the problem 1/2 fixed. The blinker and tail-light work fine but the brake light doesn't. When you press the brake pedal the light goes out completely. The new socket isn't attached to the housing the way the factory socket was so I'm guessing I have an open ground problem.
Thoughts? Opinions?
Old 06-28-2011, 03:50 PM   #6
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
F things F...try a new bulb, make sure the contacts are installed correctly in the socket, should be a tab on the fiber plate and groove in the socket.
PFC
"Tahawus"
RLC
Its a crooked piece of time that we live in.
John Prine
Old 06-28-2011, 06:02 PM   #7
Well Preserved
1993 21' Sovereign
Thoughts? Opinions?
The blinker and brake use the same filament, so the bulb isn't the problem. I'd look at a bad ground.
Old 06-29-2011, 05:30 AM   #8
1971 23' Safari
Lilburn , Georgia
Bad ground was the problem. Attached a wire from the socket housing to the can and viola, problem solved. More or less a temporary fix until I upgrade to LED. Thanks for the replies.
Tail Light Monitors? MDSilverado Lights - Interior & Exterior 3 10-19-2015 07:15 PM
LED light kit for the Monarch stop tail and turn light Dan@LED4RV Commercial Listings 5 05-12-2014 05:05 AM
Newbie needs soft floor repair advice lbdesign Repairing/Replacing Floor &/or Frame 20 09-10-2012 11:32 PM
'88 Excella tail light bexel (or mounting frame) okiedebi Lights - Interior & Exterior 0 06-18-2011 02:10 PM
Replace Tail Light Bezel on 1971 Safari pickerdd Lights - Interior & Exterior 2 05-31-2011 07:20 PM
