Originally Posted by jimmini
Just took out my fluorescent light tubes and direct wired in LED strip lights in kitchen and reading light in bed room.NOW my radio has static when lights are on.
What is a fix for that a filter in light circuit?
More than likely the regulators in the LED lights are radiating noise, likely starting right at each LED strip. I haven't tried to listen to the radio since I made the same modification, so I may have the problem too. Turn on the radio and then one light at a time to see if they all do it or just a few. Then unplug the antenna cable from the radio to ensure that the noise is coming in over the antenna. If not, a filter in the radio power leads might help.
Assuming the noise is being radiated to the radio antenna, the first thing I would try is wiring a .01 uF capacitor across the power leads right at the circuit board. If that doesn't work, try grounding the minus lead of each strip to the interior skin with a small sheet metal screw.
Noise problems are hard.
Al
