Old 05-25-2017, 04:50 PM   #1
jimmini's Avatar
1989 29' Land Yacht
Mesa , Arizona
Images: 43
Help LED light problem
Just took out my fluorescent light tubes and direct wired in LED strip lights in kitchen and reading light in bed room.NOW my radio has static when lights are on.
What is a fix for that a filter in light circuit?
Live every day as if it is your last one and one day your going to be right.
jimmini is offline   Reply With Quote
Old 05-25-2017, 05:04 PM   #2
Al and Missy's Avatar
2002 30' Classic S/O
Fleming Island , Florida
More than likely the regulators in the LED lights are radiating noise, likely starting right at each LED strip. I haven't tried to listen to the radio since I made the same modification, so I may have the problem too. Turn on the radio and then one light at a time to see if they all do it or just a few. Then unplug the antenna cable from the radio to ensure that the noise is coming in over the antenna. If not, a filter in the radio power leads might help.
Assuming the noise is being radiated to the radio antenna, the first thing I would try is wiring a .01 uF capacitor across the power leads right at the circuit board. If that doesn't work, try grounding the minus lead of each strip to the interior skin with a small sheet metal screw.
Noise problems are hard.
Al
Old 05-25-2017, 07:28 PM   #3
Overkill Specialist
GMFL's Avatar
2020 30’ Globetrotter
2014 23' International
Dadeville , Alabama
Were the LED strips CHEAP. If so that's the problem. CHEAP ELECTRONICS create noise.
Old 05-26-2017, 12:18 PM   #4
1979 23' Safari
Wayland , New York
If it's an older radio try a 12v inline noise filter on the power inlet to the radio. Especially if the noise is there on cd function as well.
Old 05-26-2017, 06:49 PM   #5
jimmini's Avatar
1989 29' Land Yacht
Mesa , Arizona
Images: 43
CD function what is that I still have cassette tape.
thank to all will try both your fixes
Old 05-26-2017, 06:58 PM   #6
jimmini's Avatar
1989 29' Land Yacht
Mesa , Arizona
Images: 43
CHEAP LED NO They may make CHEAP ones but all I buy are way to many $$$$.
Cheap charley no buy Saigon tea
Old 05-26-2017, 08:35 PM   #7
drew05's Avatar
2011 25' FB Flying Cloud
Peculiar , Missouri
I have a similar issue with factory installed LED's...
drew05 is offline   Reply With Quote
Old 05-26-2017, 11:00 PM   #8
1979 23' Safari
Wayland , New York
I have this problem when my water heater is running in my SOB. High pitch noticible whine through the stereo. It's a pos rv oem stereo center. Don't care enough to fix it in the thing though. The radio I put in my AS rocks out, keeps me motivated while working.
LED Light Problem mcomeaux Lights - Interior & Exterior 6 09-21-2016 10:40 PM
2006 led tail light problem kcplus2 Lights - Interior & Exterior 5 02-09-2012 09:33 AM
Clipper, Hella LED, Design Line Hella, LED Kit, Stop/turn LED masseyfarm Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 1 12-15-2010 11:03 AM
LED Tail Light Problem wdkueser Lights - Interior & Exterior 7 09-16-2006 06:58 PM
