Old 03-06-2010, 05:42 AM   #1
1978 28' Ambassador
Savannah , Georgia
Has anyone seen my outlet?
Hooked up new battery to '78 Ambassador 28' rear bath that has been resting for 8 yrs. I have lights! Granted they are sort of green with mildew and dirt. Have looked at wiring diagrams and an outlet is shown for the microwave. I'll be dang if I can find it. Is it hidden from sight? What are the chances the outlet was never installed? Would like to have an outlet for microwave and toaster. Other than pulling out cabinet, is there a way to see if the wiring is back there?
Also missing vacuum and nutone appliance.....
The galley switch over the sink: what does it control? The two lights above sink work using each side switch.
Exhaust fan does not appear to be working. It should come on when the vent is opened?
Did I mention I have lights? Added surprise was that the vent light has mood lighting: 6, 4, or 2 bulbs.
Thanks. Jack
Skamper1 is offline   Reply With Quote
Old 03-06-2010, 07:32 AM   #2
FT RVing
lebolewis's Avatar
1976 31' Sovereign
Always searching for a place w/low Humidity , FT RVing, N & S, E & W, & in between
Jack....do you have a gas/elect Frig? If yes, your microwave and Frig AC outlet is behind the Frig and can be accessed from the back side using the outside door behind the Frig. You will have to run an extension from there, behind the cabinet and along the wall, to a convenient spot next to your microwave. That's what I did. Bill
When you get a chance to "Dance" or "sit this one out".......I hope you DANCE!
lebolewis is offline   Reply With Quote
Old 03-06-2010, 11:53 AM   #3
1978 28' Ambassador
Savannah , Georgia
Will check it out. Thanks. Think I see a power strip in my near future.
Adding an outlet Boondocker Electrical - Systems, Generators, Batteries & Solar 45 03-10-2010 08:06 PM
12 V outlet BillTex Lights - Interior & Exterior 4 09-28-2008 12:33 PM
mystery outlet jpeterman Electrical - Systems, Generators, Batteries & Solar 8 08-08-2008 08:06 PM
T V outlet Gene Wissink 1974 - 1979 Sovereign 0 01-19-2004 07:56 AM
Looking for Outlet Cover 63flyingcloud Electrical - Systems, Generators, Batteries & Solar 3 06-30-2003 11:30 AM
