Old 09-06-2010, 09:14 PM   #15
Edgewood , New Mexico
RV-LED.com - Your source for all things LED for your Recreational Vehicle! is another source for LEDs
2005 GMC CC 4x4 D/A
rogerthat is offline   Reply With Quote
Old 09-06-2010, 10:34 PM   #16
Harry W's Avatar
1978 31' Sovereign
Scottsdale , Arizona
Don't handle them with your bare fingers. Don't ask me why, but fingerprints will cause them to burn out.
Harry W
4CU Charter Member
AIR # 13858, WBCCI # 2420
Harry W is offline   Reply With Quote
Old 10-18-2010, 05:19 PM   #17
Fulltimer Since 9/13/2010
carped8ta's Avatar
2008 27' International CCD FB
Campbell , California
Send a message via Skype™ to carped8ta
I am replacing my halogens with LED's (C9WWThin 9 Led Chip Warm White from odmrv.com) as soon as I can figure our how to open the fixture. Seems to be hermetically sealed...
carped8ta is offline   Reply With Quote
Old 10-18-2010, 08:23 PM   #18
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
Of you're talking about the round puck lights in your ceiling...the inner-most ring (the one holding the lens) pops out of the fixture if you wedge a sharp knife edge or screw driver under the edge...be careful not to scratch the fixture or your ceiling...and do this when the halogen lights are off and cool...they get VERY hot when they are on. Be careful not to drop the lens when it pops out...sometimes they come loose from the ring. just remove the halogen bulb and replace it with the LED... The whole fixture is held in the hole in the aluminum by a spring set-up, but you don't need to remove the fixture to replace the bulbs... Hope this helps.
TB & Greg and Abbey Schnauzer
#3954
Old 10-19-2010, 06:15 AM   #19
Dan@LED4RV's Avatar
Denton , North Carolina
pic to change light
Here is a picture that shows where to pry to get the bulb out.
Also, how to get the lens back on. If you don't line it up correctly it won't go on and if you force it you will bend the little clips.
Dan Brown
Denton NC
Dan@LED4RV is offline   Reply With Quote
Old 10-28-2010, 10:24 PM   #20
RichHog's Avatar
1972 25' Tradewind
Houston , Texas
If it wasn't answered above they are 10 Watt bulbs. Got some replacements at Loews.
RichHog is offline   Reply With Quote
Old 10-29-2010, 08:16 AM   #21
carped8ta's Avatar
OK, I have replaced the halogens with the LED's after learning the pry-bar technique. The little wire holes are tricky to line up as well, and replacing the lens cover isn't without it challenges. So, overall, not exactly a user-friendly interface. But they do make a great replacement, at significantly less energy consumption.
LED Replacement for Halogen Cabin Lights nangoff 2002 - 2005 International 19 10-27-2014 10:56 AM
Overhead Halogen lights in '07 Safari deauxrite Lights - Interior & Exterior 4 01-06-2010 06:21 PM
Recessed lights - should I go LED or Halogen for more options? ronstory Lights - Interior & Exterior 6 09-21-2008 08:52 AM
Dimmer for halogen lights altamont 2007 Safari SE 19 02-06-2007 11:02 PM
Bumper Halogen Lights - '88 Classic 345 MH jslee77 General Motorhome Topics 2 11-24-2003 11:23 AM
