Old 02-02-2011, 06:52 AM   #1
Stockbridge , Georgia
Hall lamp wiring?
Well Bonehead me can't figure out how to wire my hall lamp back. Looks like the PO had re-wired it & reinstalled it using just electrical tape, but the lights would work sometimes and some times not. Sooo I pulled it down to figure out the why, it was the switch. Now the switch is supposed to have 3 wires that connect to the lamp mine had only 2 and was re-wired to work with 2 wires. I found a old Airstream lamp, stripped the switch and I'm ready to wire it back together but I can't figure the wiring out. I think it's supposed to work w/ 2 lights and then 4 lights w/ each turn of the switch, maybe I'm wrong. Anyway can anyone tell me how to re-wire this lamp or point me in the right direction?Click image for larger version
mikvw is offline   Reply With Quote
Old 02-02-2011, 08:10 AM   #2
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
I think this will work
First; make sure it will have a good ground. Next; connect the wires at 3 o'clock and 9 o'clock to the black wire coming from the switch. then connect the wires at 12 o'clock and 6 o'clock to the blue wire coming from the switch. Last; connect the red wire on the switch to the +12 volt supply.
TG Twinkie is online now   Reply With Quote
Old 02-02-2011, 08:34 AM   #3
When I get home I'll do it, thanks for the help. The wifey will be happy!!
Old 02-02-2011, 09:13 AM   #4
garry's Avatar
1969 31' Sovereign
Broken Arrow , Oklahoma
TG Twinkie has it like you want 2 lamps / 4 lamps/ off.
The green wire goes to ground.
Garry
Old 02-02-2011, 12:12 PM   #5
roger that.
Old 02-03-2011, 07:06 PM   #6
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Did it work?
Old 02-04-2011, 06:33 AM   #7
Finally got to it last night to do a test and it works perfectly! This weekend I will replace the old connectors w/ new and use liquid tape to seal, then reinstall and finally have a frosty one for you guys. Much appreciated TG & Garry.
1979 sovereign, lamp wiring
Electric Horn wiring diagram on a 345 John H. Classic Motorhomes 11 11-21-2018 10:34 AM
Questions on wiring brakes and lights the544man Brakes & Brake Controllers 7 02-14-2011 07:20 PM
A.C. wiring diagram for 66 safari 386kustoms Electrical - Systems, Generators, Batteries & Solar 1 01-29-2011 08:16 PM
Around-the-World Caravan Thank You Marco Polo PeeWee WBCCI Forum 29 01-14-2011 05:05 PM
