Old 02-15-2015, 08:37 AM   #1
1994 34' Excella
Kalamazoo , Michigan
GFI breaker tripping
All of a sudden, the GFI breaker for the galley and bathroom started tripping, and will not reset, with nothing plugged into outlets. There is no continuity from hot to ground that I can detect. I'm thinking bad breaker. Any other thoughts out there? Anyone else have GFIs go bad?
Thanks...
Tom
TomS is offline   Reply With Quote
Old 02-15-2015, 08:40 AM   #2
1994 34' Excella
Never mind...just did a search, and it seems this is a common problem...I'll just replace it...
Old 02-15-2015, 09:10 AM   #3
HowieE's Avatar
Princeton , New Jersey
Images: 12
if replacing it doesn't solve the problem try removing items that are plugged into the circuit one at a time. Many older appliances had a capacitor across the line before the transformer in the items power supply. The charging current of those caps would be enough to trip a GFI. That is an old problem but you may have some old equipment.
2004 Excursion 4x4
Old 02-15-2015, 12:59 PM   #4
1994 34' Excella
Thanks, Howie...I replaced the breaker, but it's still tripping. The only thing on that circuit is the fridge. I replaced the gfi with a std breaker for the time being, which is working fine, but I have some more sleuthing to do.
T
Old 02-15-2015, 01:01 PM   #5
1994 34' Excella
Ps, I meant that I unplugged everything on that circuit ex the fridge...
Old 02-15-2015, 01:36 PM   #6
HowieE's Avatar
Images: 12
Put the breaker back and unplug the frig. I can't see why the frig should be on a GFI, but then again the Do Gooders may have a reason.
The control board of the frig may be the problem. Test it out.
2004 Excursion 4x4
Old 02-15-2015, 02:09 PM   #7
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
If you have access to the back of the fridge. Disconnect the heating element and try again.
Old 02-15-2015, 02:31 PM   #8
1994 34' Excella
Yup, that should isolate the fridge! Thanks!
Old 02-15-2015, 02:43 PM   #9
HowieE's Avatar
Images: 12
Unplugging the frig will isolate it. The heater element would not trip a GFI unless it was a dead short to ground and that would blow the fuse on the control board.
2004 Excursion 4x4
Old 02-15-2015, 05:28 PM   #10
richinny's Avatar
2011 34' Classic
check for dampness in the outside outlet and the area where the fridge plugs in. in my 94 34 those conditions caused my gfci to trip a few times. they were all on the same circuit.
Ricky
Old 02-15-2015, 05:58 PM   #11
mayco's Avatar
1982 31' Airstream 310
champaign , Illinois
Note that the neutral AND the ground leads can trip the gfi when you are troubleshooting, not just the hot lead.
mayco is offline   Reply With Quote
new power supply now tripping GFI housebg Batteries, Univolts, Converters & Inverters 32 04-16-2009 01:15 PM
GFI tripping altamont Batteries, Univolts, Converters & Inverters 19 09-04-2008 11:22 AM
Dometic RM100 tripping GFI tschat Refrigerators 3 08-21-2006 09:01 PM
GFI breaker keeps tripping. Van Electrical - Systems, Generators, Batteries & Solar 10 08-06-2005 11:33 PM
GFI Tripping grizzy Electrical - Systems, Generators, Batteries & Solar 3 09-07-2004 06:17 PM
