Old 09-08-2013, 03:33 PM   #1
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Any one care to offer thoughts?
We camped with no issues several days.. In spite we had over an hour of a single rainbow, when arriving home and plugging in, I had two failures.
Failure #1
GFCI tripped and won't stay "on"
Failure #2
Sharp MW convection oven panel fried. The bottom component on the board exploded. Well, smoked and blistered real bad. Can't even tell what it was... Looks like an old button cap..
Location, Pecan Park RV Also the cable didn't work.
Peace and Blessings..
Channing
WBCCI# 30676
Old 09-08-2013, 03:38 PM   #2
kmaggard's Avatar
1994 21' Sovereign
Paradise Valley , Arizona
Do you know if a GFCI does not have power it will not stay on? Check your breakers.
WBCCI# 2520
AIR# 77458
Ken and Ben the Saint
Paradise Valley, Arizona
kmaggard is offline   Reply With Quote
Old 09-08-2013, 03:42 PM   #3
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Yessir, all other circuits running cool.
Channing
WBCCI# 30676
Old 09-08-2013, 07:28 PM   #4
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Ok. Here is fried MW board
Also replaced GFCI. All power restored.
Got recommendations on cause and possible protective action?
Channing
WBCCI# 30676
Old 09-08-2013, 07:37 PM   #5
garry's Avatar
1969 31' Sovereign
Broken Arrow , Oklahoma
Have you checked the incoming voltage with a meter?
A GFCI trips when it detects voltage on the ground wire you may have an open neutral caused when you unplugged from the CG pedestal or plugged in at home.
Garry
Old 09-08-2013, 07:52 PM   #6
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
It may have been at home. Someone else plugged in then we discovered problems.... Things worked at RV park until I shut off the main inside then disconnected at pedestal. Same procedure I always used.
Voltage is 122-121!!! Solid neutral and grounds.
Channing
WBCCI# 30676
