Old 08-15-2007, 11:26 PM   #1
campngirl's Avatar
1964 24' Tradewind
dousman , Wisconsin
Gauge of wire used for running lights
Hi All,
I have looked throught the exterior lighting threads and I could not find any mention of the gauge of wire used for clearance lights, tail lights, ect. My wiring for the exterior lights is not in the best shape......also...copper or aluminum wire?
Any help would be greatly appreciated.
Karol
campngirl is offline   Reply With Quote
Old 08-16-2007, 12:12 AM   #2
lewster's Avatar
Naples, FL , Hood River, OR
Originally Posted by campngirl
Hi All,
Karol
Hi Karol,
I always like to over-do the wiring a little, so I would use a minimum of 16 AWG and preferrably 14 AWG. Be sure NOT to use lamp cord.....rather, go to a marine supply store and get what is called '105*C' wire used on boats. It is tinned copper with a heavier insulation layer, and the best stuff you can use in this application.
Old 08-16-2007, 12:53 PM   #3
campngirl's Avatar
1964 24' Tradewind
dousman , Wisconsin
Lew,
Thank - You so much. That is just the info that I was looking for.
Love this forum.
Karol
Old 08-16-2007, 01:55 PM   #4
Hi All,
Karol
Airstream used 16 gauge wire.
We also suggest using the next larger size wire, namely a 14 guage, as lewster suggested as well.
Using a larger size wire than necessary is a good thing.
Using a smaller size than required, is a very bad thing, always.
Old 08-16-2007, 03:27 PM   #5
campngirl's Avatar
1964 24' Tradewind
dousman , Wisconsin
Thank - You Andy for your knowledgable advice.
Loving this forum.
Karol
Old 08-21-2007, 07:49 PM   #6
Streamline Imperial
SilvrSausage's Avatar
Bellflower , California
With 14 or 16 gauge wire, you won't go wrong.
If you are switching to LED lighting, you could go thinner theoretically. However, the minimum wire gauge in a circuit should be limited not by the LOAD but by the FUSE!
Say your 14 gauge circuit is protected by a 20 amp fuse; a short way at the back of the trailer will blow it. If you decide to use smaller gage wire, the wire might catch fire before blowing the fuse, should there be a short. Even if it doesn't set the vehicle alight, it is a real mess when one wire randomly burns into other wires in the same bundle along their whole length!
If you go to a smaller gage, run smaller fuses.
It seems I love the mountains and deserts more than my friends do. I sure miss them!
1971 Streamline Imperial project "Silver Snausage", 1985 Coleman tent trailer, 1964 Little Dipper, 1975 Northwest "Proto Toyhauler", 2004 Harbor Freight folding, still seeking my Airstream.
SilvrSausage is offline   Reply With Quote
Old 08-21-2007, 08:05 PM   #7
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
I agree, I would use 14 gauge, and upgrade from the OEM 16 gauge.
SuEllyn & Brian McCabe
two tiny orange lights on left front side trailer overlander Lights - Interior & Exterior 25 12-03-2008 07:50 PM
marker lights dont work wb13798 Mechanics Corner - Engines, Transmission & More... 6 11-09-2002 11:40 AM
Broken wiring in tail lights Argosy74 Electrical - Systems, Generators, Batteries & Solar 4 10-23-2002 09:09 PM
Extra wire susan martin Batteries, Univolts, Converters & Inverters 3 09-21-2002 07:52 AM
Trailer lights Dbraw Electrical - Systems, Generators, Batteries & Solar 1 09-13-2002 04:51 PM
