Old 11-08-2013, 06:58 AM   #15
CLOUDSPLITTER "Tahawas"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up
Originally Posted by 62overlander View Post
Mc Master Carr. McMaster-Carr
Originally Posted by eubank View Post
Great source, Frank! I need some grommets for the ... well, not for the Airstream at the moment, but for the MG.
Lynn
A great source!!!!...you won't find these in stainless at the local HD.
small stuff bug's me
ID:	199556   Click image for larger version
PFC
but I’m the Husband, so we went to Cleveland. 😂
RLC
Step aside Starbucks, this is a job for alcohol.
Old 11-08-2013, 07:01 AM   #16
eubank's Avatar
1967 30' Sovereign
1999 31' Land Yacht
Bosque Farms , New Mexico
Oh, wow, those latches look like the originals, but in stainless! Did you have to drill new holes, or do the new ones fit with the old holes?
Lynn
WBCCI 21043
Old 11-08-2013, 07:12 AM   #17
Thumbs up
Lynn
No drilling needed.
Just had to emery the 'slag' left by whomever drilled the original holes.
PFC
RLC
Old 11-08-2013, 08:50 AM   #18
robwok's Avatar
1964 26' Overlander
Richmond , Virginia
Images: 35
I have to drill out my teardrops. In the VTS teardrops, there is groove that the plastic lens sits in. I rolled up butyl tape, but the aluminum was so soft, that it buckled under the small amount of tape and the lens wouldn't sit flat.
Best option I've found is to use Vulkem on either side of that grove on the backside, then putting on with Olympic rivets, then sealing the hole inside with vulkem where the wire goes through.
Some folks put silicone to hold down the lens and seal water out of that as well.
robwok is offline   Reply With Quote
Old 11-08-2013, 07:49 PM   #19
Ottawa , ON
Hmmm... I thought silicone and aluminum was a no-no.
Old 11-08-2013, 08:36 PM   #20
Question
The lens touches the AS?
PFC
RLC
Old 11-09-2013, 07:23 AM   #21
Ottawa , ON
Ah, OK, I get it. Thanks!
Electrical issues with clearance lights 1987_345 Classic Motorhomes 13 08-25-2011 08:13 AM
Gaskets for running lights? captmatt Leaks - Weatherstrips, Gaskets, Caulks & Sealants 0 08-08-2011 07:14 PM
LED interior lights: A complaint hampstead38 Lights - Interior & Exterior 0 03-23-2011 08:38 AM
Minus these lights SilverHoot Lights - Interior & Exterior 20 02-13-2011 09:04 AM
Bedroom lights won't work! julieibach Lights - Interior & Exterior 1 01-24-2011 10:14 PM
