While camping this weekend several of the lights in my daughter's "74" Tradewind stopped working: the Galley lights, the Scare light over the door, and the six lights in the mid trailer overhead vent. Are these all on the same circuit? Couldn't find any blown fuses. Other 12v lights work. Any thoughts? Thanks!
Bob Leopold, Indiana, PA
"Roadrunner"
WBCCI 4871
TAC PA 5
The scare light is not over the door, the step light is. Scare light or step? The overhead lights are on the same circuit as the scare light. The galley lights may be. You need a diagram. I have a 75 service manual for sale. Send me a pm if you are interested.
Bob, just take them apart and test them until you find the culprit. My guess is first bad one in loop.Worse case you can simply run a good 12 volt from a known source and it'll fix your problem.
Was able to get a hold of a "74" tech manual...yes they are all on the same circuit. And yes it is "over the door" light...no Scare light on "74". This may be easier to address than the refrigerator that croaked. Thx guys!
Original Univolt? You might try the fuse panel and take a test light to make sure the load side of all the circuits are getting power. No scare light? My 71 TW does. My 73 does. My 75 does. My 93 does (only have the 71 and 93 now)
