Old 06-02-2012, 06:39 AM   #1
Vblgrl9's Avatar
1978 31' Sovereign
Raleigh , North Carolina
Galley lights and power loss
When i am on dc power and turn on my galley lights i go from full batt power to nothing........ if i turn off galley lights my info cluster turns back on and i registers full power, it was doing this at first and i moved the batts a bit and everything worked as normal now its back to power loss like i have a short or something any suggestions(previous owner installed florescent units for galley and the front over head light and these are both my problem and the only issue all other things work.) 1978 sovereign 31' center bath
Vblgrl9 is offline   Reply With Quote
Old 06-02-2012, 07:26 AM   #2
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
When you have the problem lights on. Will the pump still run? If so, it sounds like you have a bad connection in the lighting circuit. Is the cluster on that same circuit? If you have the old glass fuses you may have a bad fuse or holder affecting that circuit. If everything goes dead, I would suspect a battery connection either at the battery or at the fuse panel. Check both positive and negative connections.
Old 06-02-2012, 08:14 AM   #3
Vblgrl9's Avatar
1978 31' Sovereign
When I turn the galley lights on nothing works, no other lights, pump ....etc and when I turn it off everything works.
Old 06-02-2012, 08:29 AM   #4
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
I would start by disconnecting the galley lights one at a time. You may have a bad ballast in one of the fixtures.
I would be concerned about a short if you were blowing fuses.
I am still leaning toward a bad connection causing the voltage drop and affecting all other DC stuff. If you have a bad ballast causing the high current draw and not blowing a fuse. The voltage is dropping somewhere. At a battery connection for example. No voltage=no current=no fuse blown.
Old 06-02-2012, 08:36 AM   #5
Vblgrl9's Avatar
1978 31' Sovereign
I will start by checking my batt connections first a loose ground could cause all this right?
Old 06-02-2012, 08:58 AM   #6
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
You may have more than one issue. The pump is a high current draw device as well as the furnace blower. If you leave the galley lights off, then turn on the furnace blower along with starting the pump and they will run. I would say your connections are OK. If you try to turn the galley lights on while the furnace blower is running and everything dies then I would look into the galley lighting as mentioned earlier.
Old 06-02-2012, 09:09 AM   #7
Vblgrl9's Avatar
1978 31' Sovereign
Ok thank you for your help I will let you know
Old 06-02-2012, 10:19 AM   #8
1974 Argosy 20
Kooskia , Idaho
Battery connections most likely. Clean both battery terminals and wires and I bet you will be back in business.
