Old 03-15-2009, 08:33 PM   #15
Got gandkids?
Jim & Susan's Avatar
'Possum Holler , Georgia
Originally Posted by redhawkerII View Post
Jim and Susan, do you folks have any pictures of what you did? We do have a Auto zone but I would be obliged to just copy what you did, andd how you went about doing it...Thanks if you can do this.
It's in my Full Monte thread someplace, Let me see if I can find it.
http://www.airforums.com/forums/f226...nte-15132.html
www.nesa.org
Air No. 6427
Old 03-15-2009, 08:46 PM   #16
Got gandkids?
Look around post 366 for the LED info. Look around post 360 for the other electrical wire stuff. Good luck guys. Life is busy right now, or I'd give a more detailed explanation.
JIM
www.nesa.org
Air No. 6427
Old 03-19-2009, 01:36 AM   #17
2015 25' Flying Cloud
Chandler , Arizona
Originally Posted by Jim & Susan View Post
I bought a set of 4 blue LED's at AutoZone for about $25. I used one in the light over the door and then built a mount to go under the steps for the other 3. Looks great at night.
Jim,
Can you be more specific on that LED? What were the specs? Where to buy/ How to mount it? I took our light apart today, and wow it was way corroded. Just two wires coming out. Any help would be appreciated! Thanks.
Z
Zelda is offline   Reply With Quote
Old 03-19-2009, 01:57 AM   #18
Chandler , Arizona
JIM
Got it!
Man, reading through that stuff...YOU deserve some type of medal!!! Polished aluminum of course!
Thanks so much for sharing that restoration.
Zelda
Old 03-26-2009, 11:10 PM   #19
RichHog's Avatar
1972 25' Tradewind
Houston , Texas
Porch Light Wiring
Got the light to work but it's a booger. So here's a few things I learned.
Two wires go into the light fixture but only one is needed which is the hot 12V wire. The body of the trailer is the ground and it needs to be cleaned to make a connection. The socket itself was rusted on the base. I took it and scrapped it with a wire brush inside and outside, then sprayed WD40 on it. The base of the socket still worked but needed some TLC. I have no idea what the wiring color scheme means. A wire may start out black at the wall switch and then be white or red at the light socked. I never know which is the hot wire by color. Use a volt meter and set it to DC (mine to 50 scale) to read 12 volts. Using the ohm meter to track down a wire for continuity is essential. I tracked the wires from the light to the door side switch. There was no 12V there at all. Had to locate the hot wire on the switch for the outside light. Then drill a hole through a metal brace to pull a new wire over to the switch by the door with a coat hanger. Also have spare SFE 12V 20 amp fuses handy, you'll need them.
Get them at an Auto parts store, don't waste time at Lowes or Home Depot.
RichHog is offline   Reply With Quote
Porch light cleaning GlenCoombe Lights - Interior & Exterior 10 06-30-2013 02:16 PM
Porch Light Placement toddster Lights - Interior & Exterior 8 12-27-2008 05:18 PM
LED Porch Light RLS Lights - Interior & Exterior 11 09-18-2008 11:19 AM
Porch light for sale azfiredog300 Roof Vents, Skylights & Fans 50 02-11-2008 11:09 PM
The $8 Porch Light Silverfly 1960 - 1964 Overlander 2 09-21-2004 06:25 PM
