79' Sovereign- ok so all the lights worked earlier. Then all the sudden, the back half of the trailer (including outside plug) went out.... So I got in the closet and tested the breaker. Everything went smooth, so I reset everything, and now, the front lights don't work (front room, kitchen) I checked fuses too. There is one switch on the box that isn't up and is in the "off" position... Does that run the front (the top middle)?
