Old 09-01-2016, 08:19 PM   #1
1977 31' Sovereign
Fort Wayne , Indiana
Front Clearence Light Wiring Harness - Access
I was replacing my old front clearance light with a bulb type - cheaper, $2.99 at Big R - when the wire came loose from the wiring harness.
Is there an easy fix for this, or do I have to remove the bulk head to get to the wiring harness.
I had it almost fixed when I saw that I needed to cut the wire to the clearance light shorter. I must have played with the wire too much and it unplugged from the wiring harness inside the wall.
I thought of either fishing a wire to the middle clearance light, or running a new wire from the fuse bus.
I also thought of taking it to the local dealer (non-Airstream) and having him take a look at it - at $85 bucks an hour.
Your advice would be appreciated.
If there is a video, I could use the link too.
Thanks.
TradeWind77 is offline   Reply With Quote
Old 09-01-2016, 09:35 PM   #2
1991 25' Excella
Stanfield , Oregon
Im curious about this myself since I did the same thing.
SpletKay06 is offline   Reply With Quote
Old 09-01-2016, 10:04 PM   #3
nickclifford's Avatar
1972 31' Sovereign
felton , California
this must be common occurrence ! my son did the same thing , the wire just popped back inside the shell. Gone forever ....
nickclifford is offline   Reply With Quote
Old 09-02-2016, 04:44 AM   #4
2000 30' Excella
Toledo , Ohio
Going from the inside is the only way to fix it at least thats what I had to do on my 2000
woodfox45 is offline   Reply With Quote
Old 09-26-2016, 06:19 PM   #5
1977 31' Sovereign
Front Clearence Light Wiring Harness Access
When you said you went from the inside on your 2000, was there an access panel, or did you go through the bulkhead storage.
Old 09-26-2016, 06:20 PM   #6
1977 31' Sovereign
What did you do, remove the bulkhead? Or did you cut an access hole?
Old 09-27-2016, 04:42 AM   #7
2000 30' Excella
Toledo , Ohio
The 2000 Excella has a storage cabinet instead of a bulkhead it is made of Oak I cut access hole to get at the wires . Hope this helps , you won't believe the sloppy kind of wiring job the factory does .
Spartan tire size and ground clearence Schneider591 Vintage Kin 0 08-27-2016 10:13 PM
Coach wiring harness to batteries ? John H. Classic Motorhomes 16 03-28-2011 10:52 PM
New wiring harness RiverRat Lights - Interior & Exterior 9 06-16-2009 02:42 PM
7 Pin Wiring Harness Replacement Jake Electrical - Systems, Generators, Batteries & Solar 4 09-27-2005 08:05 PM
