Old 10-13-2014, 07:18 PM   #1
1967 20' Globetrotter
Newcastle , Maine
Front Clearance Lights - '67 Globetrotter
Both of my front clearance lights are out on my 67 Globetrotter. The rear ones and taillights are fine. Where/how can I access the connection where the power to the front clearance lights ties in with the rear/taillights? Thanks in advance for any help on this!
badgoat is offline   Reply With Quote
Old 10-13-2014, 07:34 PM   #2
68 TWind's Avatar
1968 24' Tradewind
Oxford, , Mississippi
I had several clearance lights on my 68 that did not work with I got the trailer and I was afraid of a wiring issue. With a little checking, I found that the ground was bad (the connection between the base and the trailer skin). I drilled out the rivets holding the bases down to the trailer and cleaned up the connections and checked for 12 volts. A little vulkem in the hole where the wire came out and new rivets to reattach the base and they all worked.
Bruce & Rachel
68 Trade Wind
2001 Toyota Tundra
Where do i buy ? Light fixtures / tale lights Front lights missing Airgirl1 General Repair Forum 4 02-27-2012 05:04 PM
Clearance Lights-3 front and rear SilverHoot Lights - Interior & Exterior 13 01-12-2010 12:19 PM
Running marker / clearance lights unhooked Kistler Electrical - Systems, Generators, Batteries & Solar 19 12-18-2006 07:30 PM
Front Clearance Lights Chaplain Kent Classic Motorhomes 2 07-13-2006 10:29 AM
Upper Identification Lights aka(Clearance Lights) pap Lights - Interior & Exterior 7 04-08-2003 06:14 PM
