Old 07-19-2010, 10:51 AM   #1
2007 27' Classic FB
Bellingham , Washington
Question Fluorescent light problem
I have a 2007 classic limited 27' AS. The fluorescent light above the galley sink doesn't work. I have replaced the tubes and removed the fixture from under cabinet to see if any wires were not connected. What should I try next?
vhaalen is offline   Reply With Quote
Old 07-19-2010, 10:57 AM   #2
banjobill
wmarsha's Avatar
2000 30' Limited
battle ground, , Washington
if all else is good, then it is the ballast
how dark were the tubes at the ends? if very dark then the ballast could be toast.
check out:
www.solarseller.com
john drake services
nice guy to talk with and he knows the rv light industry.
kinda a new light to have issues...my 85 had 3 lights with bad ballasts and John fixed me up; 'course the ones I had were 25 years old.
good luck
ol' bill
wmarsha is offline   Reply With Quote
Old 07-19-2010, 12:16 PM   #3
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
check out:
www.solarseller.com
john drake services
good luck
ol' bill
I agree, sounds like the ballasts.
I have also dealt with John Drake Services. Good experience, and I won't hesitate to deal with them again.
Vaughan
Old 07-19-2010, 12:17 PM   #4
tpi
Trabuco Canyon , California
I'd hook the fixture directly to battery or known 12 volt source and see if it works (observe polarity). Or verify the fixture is getting 12 volts. If fixture is faulty, look into ballast replacement or a new fixture.
tpi is offline   Reply With Quote
Old 07-19-2010, 05:13 PM   #5
2007 27' Classic FB
More problems!
Thanks, everyone for your thoughts. The Thin-Lite tubes were dark and looking more closely at the ballast board, it appeared to have blackened on one of the parts. Since the ballast is integrated into the light fixture, I went to an AS dealer and purchased a new fixture, 30 watts to replace the 16 watts light that was bad to get more brightness in the sink area. When I tried to wire the new light in, it still doesn't work and now the stove hood fan/light are not getting power and neither is the systems monitor. What have I done?
Old 07-19-2010, 05:39 PM   #6
tpi
I'd go to the fuse panel and check for blown fuse. The fluorescent fixture needs to have polarity observed. Perhaps you wired it backwards and it blew the fuse? Or briefly shorted the wires when installing it. It doesn't take much to pop a fuse.
Excella Fluorescent Light Mystery jjfitzy Lights - Interior & Exterior 21 09-04-2014 04:21 PM
Exterior Light Problem extiger Lights - Interior & Exterior 5 10-08-2007 03:55 AM
Pilot light problem Scott Hopkin Stoves, Ovens & Microwaves 3 05-17-2005 03:16 AM
"Dim" fluorescent light in bathroom and etc. Kistler General Interior Topics 4 10-24-2004 03:24 PM
