Old 10-07-2016, 08:58 PM   #1
losfeliz's Avatar
1981 31' Excella II
Florence , Alabama
First time out - dead outlet on 2nd day
New Airstream owner - 1981 Excella II in original condition. The microwave is out, which allowed us to use the outlet for a coffee grinder and water kettle. Worked great on day one. Day 2, the outlet didn't work (to be clear, this is the outlet in the microwave opening). No fuses are out, no breakers are tripped, and everything else in the camper seems to be working fine. Other outlets all work... What are the next steps for troubleshooting?
losfeliz is offline   Reply With Quote
Old 10-07-2016, 09:12 PM   #2
CRH
1995 25' Excella
xxxxx , xxxxxx
Pull the outlet and use a tester to check for current at the wires
CRH is offline   Reply With Quote
Old 10-07-2016, 09:25 PM   #3
rodsterinfl's Avatar
2006 25' Safari
St. Augustine , Florida
Images: 8
It must be a GFCI outlet. CRH has the answer.
WBCCI 8653/AIR 60240
2017 Ford F-150 3.5 Ecobeast Gen 2 3.55 Platinum
Old 10-10-2016, 07:24 PM   #4
losfeliz's Avatar
1981 31' Excella II
Florence , Alabama
OK, thank.s I pulled the outlet and tested the wires - no juice. All other outlets test fine so I know my tester is working. If I trip breaker #1 (not a GFCI), all outlets go dark as expected. The problematic outlet isn't a GFCI outlet...and it was working just a couple of days ago. Any other suggestions to look at next?
ID:	273337   Click image for larger version
Old 10-10-2016, 07:53 PM   #5
2017 25' Flying Cloud
Gold Country , California
Check the other outlets for the GFCI outlet. It will feed all the other (then) GFCI protected outlets.
If that's not it, start taking all the outlets out like you did this one and check connections, voltage, etc. That panel doesn't look original (but I don't know anything about vintage trailers), so my guess is that the wiring is not.
Start looking at the most logical problem and then work to the "crazy, never seen that before" solution.
Good luck
NorCal Matt is offline   Reply With Quote
Old 10-10-2016, 08:01 PM   #6
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
I see from you photo you have two 20 amp circuits and one 15 amp circuit. The microwave OR the Air Conditioner is powered by one of the 20 amp circuits. My 86 as well as a lot of other Airstreams have a "light switch" that toggles EITHER the microwave OR the air conditioner. There ain't enough power on 30 amps to run both. If your air conditioner runs, your microwave outlet is not powered and visa versa.
Look for this switch that seemingly does nothing. Mine is in the galley cabinet above the stove. Maybe someone in your family flipped the switch and said I wonder what that does. Or better yet, they knew what it does and flipped it just to watch you troubleshoot.
This might be the cause.
David
Old 10-11-2016, 07:29 AM   #7
losfeliz's Avatar
1981 31' Excella II
Florence , Alabama
David that was it! A light switch above the kitchen sink! I have to blame myself though, I thought huh, wonder what that does and just thought it killed power to the AC. Thought that was odd but never connected that to my outlet issue! Click image for larger version
Name:	ImageUploadedByAirstream Forums1476192549.684565.jpg
Old 10-11-2016, 07:43 AM   #8
1977 31' Sovereign
2005 30' Safari
North Port , Florida
I wonder why some are wired this way and others aren't? Our original 81 Excella does not have this switch, and we've never had a problem running both the AC and Microwave at the same time. Glad you found the culprit though.
cliffcharb is offline   Reply With Quote
Old 10-11-2016, 09:18 AM   #9
losfeliz's Avatar
1981 31' Excella II
Florence , Alabama
Now that we no longer use that outlet for a microwave, I wonder if I can change it so that I can run the AC and that outlet at the same time. Any ideas?
Old 10-11-2016, 01:20 PM   #10
1999 25' Safari
Sparks , Nevada
Sure - Easy enough. Just remove the switch, wire nut all the like colored wires together and put on a blank wall plate where the switch came from. Be sure to put all the bare ground wires together also.
Vic H
Vich is offline   Reply With Quote
Old 10-11-2016, 06:43 PM   #11
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
I wonder if Airstream installed this EITHER / OR switch only on trailer that had a built in microwave cabinet option? I grabbed a Sharpie and labeled my switch "AC" and then "Micro". Helps an old guy keep it straight.
Many folks put a microwave on the countertop of an older trailer and don't have a problem. You just have to be cognizant that all the power you have coming in is 30 amps AC or about 3000 watts. And even that can be marginal on a hot day in a crowded campground. An air conditioner on high, full cool can pull 2000 of those precious watts. And then we plug in a 1500 watt hair dryer along with a toaster oven and suddenly the trailer goes dark.
I guess that's why some Airstreams now have 50 amp shore power just like the big fifth wheels do. We love our electricity and I'm one of the types that do.
David
dead dead bolt Jim from SB Doors & Locks 3 09-09-2012 11:32 AM
First Time and Full Time! JRoss3030 Member Introductions 9 03-20-2010 11:28 PM
First time Airstream owner & 2nd mistake gurrd80 Member Introductions 1 05-20-2008 08:02 PM
Dead ...really dead Melody Ranch Batteries, Univolts, Converters & Inverters 17 06-13-2007 12:23 AM
first-time poster.....long-time reader ("lurker") happyfella Member Introductions 3 08-21-2006 08:55 PM
