Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar > Lights - Interior & Exterior
Old 03-19-2007, 07:14 AM   #1
Cap-N-Red
Retired Fishing Guide
Cap-N-Red's Avatar
Profile:  2005 28' Classic
Port O'Connor , Republic of Texas
Question Finding electrical shorts
What would be the correct procedure for locating a direct short on one of the 12vlt. legs coming off the fuse box? It's the leg that supplies current to the reading lights over the couch , overhead living area , sink , and outside step & scare lights. I say it's a direct short because it will blow a fuse the instant you try and place a new one in the holder.
Thanks for any information in advance
Cap-N-Red
2005 GMC CC D/A
2005 28' Classic
WBCCI # 3133
Cap-N-Red is offline   Reply With Quote
Old 03-19-2007, 07:23 AM   #2
azflycaster
azflycaster's Avatar
Profile:  1975 25' Tradewind
Phoenix , Arizona
Images: 60
Put an ohm meter on the line and remove all bulbs that are in the circut. If it still reads a short, try pulling on the wires that go between the bulbs in the circut. When the meter goes from 0 ohms you have found the area of the short. It helps to have another person helping.
Richard
Charter Member Four Corners Unit
Old 03-19-2007, 07:50 AM   #3
uwe
418
uwe's Avatar
Profile:  1963 26' Overlander
1958 22' Flying Cloud
1963 19' Globetrotter
Portola Hills , California
Images: 40
I would start fabricating a light bulb holder that has 2 leads and can be pushed onto both sides of the fuse holder ( sans fuse) for the circuit in question. A short will make the bulb light up.
Now, trace the wiring until the bulb goes out - that's where your short is going to be.
Make sure that all the users in the circuit are definitely turned off. Remove one light at a time and see if the problem becomes obvious.
Uwe
I have made many electrical changes FrankR Electrical - Systems, Generators, Batteries & Solar 4 10-03-2008 09:53 AM
Electrical problem--99 safari Andrew Carey Electrical - Systems, Generators, Batteries & Solar 2 11-16-2002 03:04 PM
HELP! Electrical problem FranceyS Electrical - Systems, Generators, Batteries & Solar 4 11-11-2002 06:27 PM
electrical problem ALANSD Mechanics Corner - Engines, Transmission & More... 22 08-22-2002 10:47 PM
Electrical System Question 1985air345 Mechanics Corner - Engines, Transmission & More... 2 03-16-2002 08:39 PM
