Old 08-10-2009, 11:42 AM   #1
2009 16' International
Verona , Wisconsin
Exterior Red lights not working
Hi Everyone:
Just returned from a nice weekend trip but when I reconnected my trailer to come home the 7 red exterior lights (on back of the trailer) did not illuminate. Brake lights, turn signals, and all of the orange lights function just fine. Can anyone offer some "light" on why this may be happening and how I can fix it?
Thanks.
mico75 is offline   Reply With Quote
Old 08-10-2009, 12:01 PM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
If the orange lights worked the problem is in the trailer because both the red and orange lights are feed by the parking light circuit of the TV.
Did the parking lights in the stop lights work or just the small red light not working?
Generally Airstream run the wining down the center top of the trailer. The first place I would look is at the top 3 marker lights. Open them and see if you have power on the wire coming into any one of them. If you have power there you should be able to get that light to work by grounding it to the skin of the trailer.
If there is no power there the brake is forward of that point and most likely behind the interior skin.
There may be a chance they spliced both the front and rear marker lights at the distribution point in the front of the trailer. Look at the green wire coming into the trailer at the distribution point and see if that is a 2 wire or 3 wire connection. If 3 wires one should be the feed , the orange markers and the red markers. Test that connection.
2004 Excursion 4x4
No rear lights working on trailer NY_Chairs Lights - Interior & Exterior 7 06-21-2009 06:33 PM
Red Marker Lights daanderson Lights - Interior & Exterior 7 07-31-2008 06:47 AM
Only half of running lights working gmehal Lights - Interior & Exterior 12 07-04-2008 09:57 PM
no 12 volt lights working marifn Lights - Interior & Exterior 9 12-12-2007 06:40 PM
Overlander exterior light not working Mark&Bet Lights - Interior & Exterior 8 08-10-2006 12:29 PM
