Old 05-17-2016, 01:34 PM   #1
2015 30' Classic
Roseburg , Oregon
Exterior marker light contains water
One of the exterior marker lights has about 1/2 inch of water in it on my 2014 Classic. Does it pop off, or screw? If I dry it out and seal it, will that be enough or is there danger of a short now in the system somewhere? What kind of sealant should I use? Will I have to replace the bulb? Thanks.
Molly Presto is offline   Reply With Quote
Old 05-17-2016, 02:37 PM   #2
retired USA/USAF
2001 30' Excella
Somerset , New Jersey
The plastic lens should just pop off using a thin blade screwdriver. If it still works let it dry and put it back on. If you need to replace the whole light get one at any auto parts place and put on.
Roger in NJ
Winston Churchill 1948
TAC - NJ 18
polarlyse is offline   Reply With Quote
Old 05-17-2016, 03:55 PM   #3
BAB
BAB's Avatar
2015 30' Classic
2012 28' International
Greensboro , North Carolina
Same issue on one of my lights. This is an LED light and you cannot pop the plastic cover off. It's a completely sealed unit. I drilled a very small hole at the bottom of the light to let the water drain out. Problem fixed....but if it were to recur, I'd get it done before mine goes out of warranty. The lights aren't all that expensive to replace.
_________________
"SilverLeaf II" 2015 30' Classic
2014 RAM 2500 Laramie 4x4 CC w/6.7L Cummins
ProPride 3P
AIR# 58452
WBCCI # 3430-Unit 21
BAB is offline   Reply With Quote
Old 05-17-2016, 04:40 PM   #4
retired USA/USAF
2001 30' Excella
Ohhhh. I got it now. Mine are the old fashioned bulb type. I forgot about the LED's being a sealed unit. Still, it should be an easy replacement.
Roger in NJ
TAC - NJ 18
Old 05-17-2016, 06:50 PM   #5
rugjenkins's Avatar
1975 Argosy 28
Springville , Alabama
My led exterior lights are not sealed.
Matt
rugjenkins is offline   Reply With Quote
Old 05-18-2016, 10:40 AM   #6
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
I had several with water in them replaced under warranty. Now the warranty is out and I have several with water in them again and several with only 1 section of 4 LEDs- 1/2 of them working.
The water/moisture inside the lens doesn't seem to affect anything. I just thought a new trailer with a $94,000+ MSRP shouldn't have moisture inside the light lenses!
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 05-18-2016, 10:48 AM   #7
BAB
BAB's Avatar
2015 30' Classic
Agree that they shouldn't get water in them. But they do. I'm curious as to what kind of LED lenses Matt has. The only ones I've seen are a completely sealed unit. Well, not completely sealed as they get water in them! BTW, if you do decide to drill a drain hole, it's obviously important to do this in a spot where the drill bit doesn't enter the electronics! Oh, and those of us with the '15-'16 model Classics are a fair amount over the 6 figure mark. And, they get water as well!
_________________
ProPride 3P
AIR# 58452
Old 05-18-2016, 11:20 AM   #8
m.hony's Avatar
2013 30' Classic
The MSRP mentioned in post #6 was 2012 money for a 2013 hickory wood Classic.
TAC #MS-10
Airforums #70955
Old 05-18-2016, 11:47 AM   #9
CLOUDSPLITTER Phone home
ROBERT CROSS's Avatar
Zanadude Nebula , WNY
The teardrops leak, they be teardrops after all....
I sealed all ours with home made inner tube gaskets, they still get condensation but but the incandescent heat will usually dry them pretty quick. The older style do have a drainage slot...at least mine do.
..if it ain't broke...fix it 'til it is.
ID:	262729   Click image for larger version
Name:	SEALING THE TEARDROPS 001.jpg
"What you do speaks so loudly, no one can hear what you say"
M. Levy
So when is this..."old enough to know better" supposed to kick in?
Old 05-18-2016, 11:55 AM   #10
2012 30' International
Livingston , Texas
Moisture inLED Clearance Lights
Yup, seems to be a problem. Apparently the seals are not good on these lights. In Texas I had an anal safety inspector at an authorized AS dealer fail my state safety inspection last year because one of my clearance lights had moisture inside. I'm sure I gave him the ;deer in the head lights" look. Cost me $40 to replace it so I could leave. (this place lost my business forever) Now I have several that are wet inside the lens. And yes, a screwdriver pops off the lens but it is a bit of a fight getting it off. Thanks for the hole drilling tip. 2012 Signature.
glenrms is offline   Reply With Quote
Old 05-18-2016, 01:06 PM   #11
2015 30' Classic
Roseburg , Oregon
Thank you so much for all of your answers. I will work on getting the water out, but the big relief is that the water won't cause shorting or other problems with the electrical system in general. Is that right?
Old 05-18-2016, 01:47 PM   #12
Howard L.'s Avatar
2012 30' Flying Cloud
San Antonio , Texas
http://www.airforums.com/forums/f37/...-140562-3.html
Above: a thread on your lights and removal. Also, in the large Corrosion thread, there is a good bit of discussion about the water inside and the corrosion caused by the light bases in the 2012 - 2014 area.
You will eventually lose your LEDs with the water inside. See above M.Hony has some banks of lights out. LEDs will not heat up and therefore, the inside of a wet fixture will take forever to dry.
In short, you need to dry the fixtures out-or replace-and then seal all portions of the light/base with Acryl R or ParBond, leaving only a small area at the bottom of the base/skin for drainage--just in case of another water leak.
Howard L. is offline   Reply With Quote
Old 05-21-2016, 01:58 PM   #13
Agent 86
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
FWIW, I think that the advise given to drill a small hole in the bottom of the lens was the best advise.
But I am a practical kind of guy.
#JustSayin..
Superat stultitia.
Old 07-06-2016, 05:59 PM   #14
2015 30' Classic
Roseburg , Oregon
Drilling a hole in the bottom would have been the best solution
I had to wait until it stopped raining here in Oregon before I could attempt to drain the water out of my marker light. It turns out that BAB was right. The light is completely sealed, so simply drilling a hole in the bottom would have been the best solution. My Airstream is a 2014 30' Classic. Thanks to all for your advice.
1968 Overlander Running Light (Marker Light) Wiring Diagram or Routing Information Bunkroom Lights - Interior & Exterior 0 08-24-2014 04:12 PM
Tail Light and Marker light lens 68 TWind General Repair Forum 0 06-26-2014 11:34 AM
Water in marker light housing danlehosky General Repair Forum 1 05-13-2012 06:27 AM
Photo set-Contains no photos? KYAirstream Forum Admin, News and Member Account Info 2 03-29-2011 09:41 PM
Scare light and marker light won't work??? shinybean Lights - Interior & Exterior 12 02-12-2007 08:51 PM
