Old 06-18-2013, 10:18 AM   #1
airdreamers's Avatar
2008 28' International
Venice , Florida
Images: 14
Exterior Lights at door
Name:	Airstream Light Switches[1].jpg
ID:	188541Here we go. I seldom propose a question re stuff.
I have 2 light switches just to the left of my entrance door. The switches operate the step light and the flood light. There is no power to the over door light? Is there anyone out there know which of the switches operate this light in conjunction with either the step or flood light. The overhead light never did work at all.
Bill and Janice, We're lovin' it! (Airstreaming)
Airdreamers
WBCCI #8880
AIR #41310
airdreamers is offline   Reply With Quote
Old 06-25-2013, 12:43 PM   #2
joe chernosky
1987 29' Sovereign
Corinth , Maine
Hi Bill,
On my '87 Sovereign, the Flood switch powers the patio (scare) light and the Step switch powers both the overdoor light as well as the light alongside the steps. If neither of the two "step" lights work, I would suspect the switch. If the light next to the steps works, I would pull the 1156 over-the-door socket and see if there is power to this socket. Chances are that either the socket or switch is bad and unlikely the the wiring is bad.
Cheers,
Joe
joe chernosk is offline   Reply With Quote
Old 06-25-2013, 01:33 PM   #3
Excella CM's Avatar
1978 31' Excella 500
Venice , California
The over door light is the step switch. The scare light is the flood. Wire has probably come off of the switch terminal.
"Not all who are laundering are washed" say Bill & Heidi
'78 Excella 500,"The Silver Pullit". vacuum over hydraulic disc brakes, center bath, rear twin. '67 Travelall 1200 B 4X4 WBCCI 3737
Excella CM is offline   Reply With Quote
Old 06-26-2013, 07:15 AM   #4
Venice , Florida
Images: 14
Thanks to both you guys, Joe Chernosk, Excella CM.
Never dawned on me, wire off the switch. Very helpful to know about which lights are operated by which switch.
Now the task to check the switches, I can't wait!
Hope to come back to this post with a positive result.
Airdreamers
WBCCI #8880
AIR #41310
Old 06-26-2013, 06:34 PM   #5
beaumont , Texas
69 safari
I have the same question for my 69 safari// there is one switch on the right of the door as you enter, does not seem to activate anything. the scare light switch is further down the wall by the windows. What is the entry switch supposed to activate? my overheads work. so I am stumped. Richard
Dixie722 is offline   Reply With Quote
Old 06-27-2013, 06:34 AM   #6
Venice , Florida
Images: 14
Originally Posted by airdreamers View Post
Attachment 188541Here we go. I seldom propose a question re stuff.
Well problem solved!
The step light works the step and the over head light.
Upon removing the step switch from the wall, I see 3 wires. 2 wires on 1 side from the switch and hot on the other side, wiggled the wires and like magic everything is good. Thanks to all again for the tips etc. I was not looking forward to a wiring job.
Airdreamers
WBCCI #8880
AIR #41310
