Old 08-23-2019, 07:13 AM   #1
2020 23' Flying Cloud
Miller , MO
Exterior lights
While I was doing some prep to my 23fc, I noticed that my running lights aren't completely flat on the skin. I don't think they can be tightly screwed down since some are on a curve. Would some clear silicone be a good idea?
Eric
At1eric is offline   Reply With Quote
Old 08-23-2019, 07:39 AM   #2
1986 31' Sovereign
Miami , Florida
No. Most silicon caulks contain acetic acid which is a no-no on aluminum. If you pop the lense off of one of the fixtures you should see that the hole the wires come through is sealed with goop of some sort (at least they are on mine). This should keep moisture out of the shell wheel letting any trapped moisture escape from the fixture.
new (usually dirty) Nissan Titan XD (hardly paid for)
Old (enhanced with "male pattern baldness") Sovereign
Young, lovely bride
Goofy dog, dismissive cat
Old 08-23-2019, 08:32 AM   #3
Miller , MO
Sounds good. Thanks.
Eric
No running lights, brake lights or trailer lights work from tow vehicle RichHog 1969 - 1973 Safari 42 05-02-2019 07:42 PM
All exterior lights, brakes,tail lights, position lights. Lkjdude 2009-2015 Flying Cloud 12 10-04-2016 10:05 AM
Running Lights don't work, Other exterior lights work jrvly1976 Lights - Interior & Exterior 15 01-27-2015 09:27 PM
Should I? (adding exterior lights) bredlo Lights - Interior & Exterior 20 03-12-2004 06:48 AM
How do I test trailer exterior lights? Bryanhu Lights - Interior & Exterior 2 08-09-2003 06:27 AM
