Old 06-16-2013, 06:16 AM   #1
mercury7's Avatar
1959 24' Tradewind
easley , South Carolina
Exterior lighting review questions
I backed my truck up to the 72 sovereign last night to get a handle on my exterior lighting... Good news, quite a few of them came on ... To be exact one came on in front both sides and rear. These are all heavily sun damaged, a local truck stop has the marker lights but oddly they do not come with any rubber.
I did have one question though... If I am getting power to at least one marker light in the rear, does it seem safe to assume I will have power in my tail lights.... I think they are all just burned out but did not know if they were connected to the maker light circuit
mercury7 is offline   Reply With Quote
Old 06-16-2013, 06:28 AM   #2
mercury7's Avatar
1959 24' Tradewind
One more thing... Since the marker clearance lights I found do not have a gasket.... What would you use to seal the hole where the wire comes out of the trailer... Seems like at least some water will get in there
Old 06-16-2013, 11:00 AM   #3
1988 32' Excella
Robbinsville , New Jersey
Don't ASSUME your trailer is over 40 years old, could be a broken wire or corroded connection.
The tail lights and running lights are the same circuit.
Break lights/turn signals are 2 separate circuits.
I don't think your lights are burned out, from my experience most exterior trailer lights stop working due to corrosion, not burning out.
Old 06-16-2013, 11:10 AM   #4
mercury7's Avatar
1959 24' Tradewind
Ok thank you, I guess I will just have to start replacing stuff till I get them working
