Old 05-27-2010, 08:50 AM   #1
1972 31' Sovereign
princeton , New Jersey
exterior light over door '73 sovereign interntl
Need to replace exterior light fixture - any suggestions about best sources? (doesn't have to be original equipment).
Thx
kayaker410 is offline   Reply With Quote
Old 05-27-2010, 09:17 AM   #2
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
Which light fixture? Step Light? Scare Light? Running Light? Brake Light? There are so many.
1958 Overlander
2011 Wolf Creek 850N TC
2011 Ford F-250 Crewcab (6.2L), 3.73RE
WBCCI #5661/AIR #5661/TAC # AZ-6
4CU 1st VP
My '58 Overlander Restoration and Travel Blog:
http://mellomikesairstreams.blogspot.com/
mello mike is offline   Reply With Quote
Old 05-27-2010, 10:41 AM   #3
1972 31' Sovereign
Des Moines , Washington
I have the same prob with my 72 Sovereign, a member offered one to me but never got back to me? I am missing the entire fixture above the door.
Curt
2wheelin is offline   Reply With Quote
Old 05-27-2010, 10:41 AM   #4
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
I converted all mine to LED. The fixture on the top left goes above the door.
Name:	Airstream Lights.jpg
Old 05-27-2010, 10:50 AM   #5
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
got a source for those LED tail lights (manufacturer/model)? how'd you fasten them in?
Air:291
Wbcci: 3752
'73 Safari 23'
'00 Dodge Ram 1500 4x4 QC
Old 05-27-2010, 10:52 AM   #6
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
Ooops, sorry. My comprehension is off today.
Do you still have the housing? If all you need is the light fixture, you can buy a 12v light at any auto parts store. You can mount it then wire it using the existing wires. That's what I did and it works fine.
1958 Overlander
4CU 1st VP
Old 05-27-2010, 11:56 AM   #7
Aerowood's Avatar
Arvada , Colorado
Post 276 has some of the details on how I did it.
http://www.airforums.com/forums/f416...-26902-20.html
I got the here
SUPER BRIGHT LEDS - LED Lights & Accessories
Old 06-30-2010, 01:49 PM   #8
1972 31' Sovereign
replace outside light over door 72 sovereign intrntl
Suggestion below was very helpful:
"Do you still have the housing? If all you need is the light fixture, you can buy a 12v light at any auto parts store. You can mount it then wire it using the existing wires. That's what I did and it works fine."
Yes, I do have the housing and the wires are capped. So I found a replacement light, as suggested, but just discovered there's no power into the capped wires over the door. Does anyone know how I can figure out why there's no power?
Old 06-30-2010, 01:54 PM   #9
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
check the switch on the wall by the door, see if there is power there, if not you have narrowed it down.
Old 06-30-2010, 02:24 PM   #10
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
Very nice design on the license plate holder/light. I'll have to remember that.
Vaughan
Old 06-30-2010, 04:05 PM   #11
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
Alan gave you good advice. Check for current there at the switch. If you have no power there, look for a bad fuse for the front of your coach.
1958 Overlander
4CU 1st VP
Old 07-06-2010, 03:28 PM   #12
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
Hi Kayaker, just saw your PM. The fuse panel is located at the bottom of the your curbside closet. I'd have to look at mine to see which color wire provide 12v current to the front of your coach, but you shouldn't have too much trouble finding it yourself. Let me know if you still need help.
1958 Overlander
4CU 1st VP
Old 09-16-2010, 04:24 AM   #13
RaleighAir's Avatar
1973 31' Sovereign
raleigh , North Carolina
Switches by front door
Speaking of those switches just inside the door, what do they do? There's no mention of them in owners or service manual. I figured one was for the light over door, but the other? I don't have a "scare light".
RaleighAir is offline   Reply With Quote
Old 09-16-2010, 05:57 AM   #14
x
XXXX , XXXX
Raleighair my 73 the two switches beside the door are:
1) The porch light over the door
2) The kitchen light over the sink. It is a double pole switch because the light is also controlled from a switch located on the light itself.
My Scare Light is controlled by a switch located on the curbside wall next to the radio speaker. You can access this switch while sitting on the front couch.
Kayaker410 the main power feed for this light is the brown wire for circuit #4. It also controls the kitchen range fan,12V outlet on roadside wall for television,the front overhead light in the roof vent and the two reading lamps in the front end cap. If you have power to any of these the circuit is good. If you have no power to the switch the break is between the brown wire and the brown/yellow wire feeding the switch. If you have power to the switch the break is on the wire to the switch. The wiring diagram also shows this light using a white wire to go to ground if it is broken or the connection to the shell is corroded the light will not work.
wasagachris is offline   Reply With Quote
sovereign
1969 Sovereign :: 1969 Airstream Sovereign evers310 Airstream Registry Discussions 0 08-19-2011 08:31 AM
A handy schematic snapshot from my furnace - 1970 Sovereign ranger_rick Furnaces, Heaters, Fireplaces & Air Conditioning 1 02-18-2011 10:34 PM
