Old 09-27-2008, 04:52 PM   #1
Des Moines , Iowa
Exterior light issue
A couple of relative newbies who planned to finally get to leave in the trailer tomorrow need help---
2002 Safari. The right brake light is all the time but the right turn signal doesn't work. The left brake light and turn signal work fine. The back-up lights don't work at all. Running lights work fine.
Any help in isolating the problem area would be appreciated.
iasid is offline   Reply With Quote
Old 09-27-2008, 04:56 PM   #2
purman's Avatar
1968 28' Ambassador
Cedaredge , Colorado
The bulb might be in backwards on the right..... or part of it burnt out... have you checked the bulbs on the back up light??? sorry but this will help narrow stuff down if you have....
Jason
2008 5.7 L V8 Sequoia
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
Old 09-27-2008, 05:21 PM   #3
Des Moines , Iowa
Thanks--
This problem is not stable---
In checking out your suggestion, we took off the R tail-light covers. The light bulbs look OK. BUT now the R tail-lights are brighter than the L all the itme--even though we didn't take out the bulbs; the R turn signal works--but more slowly than the L. Still neither of the back up lights work at all--but the bulbs look fine.
Seems like the problem must be in the connection between the truck and the trailer? I've already cleaned it out w/ a q-tip but maybe I need to work on it more?
Old 09-27-2008, 05:40 PM   #4
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
It's possible you have the 12 volt charge line and the right turn signal lead reversed in the truck plug.
Old 09-27-2008, 07:25 PM   #5
1999 25' Safari
Fairburn , Georgia
Look for a missing ground circuit.
JackMac is offline   Reply With Quote
Old 09-27-2008, 08:03 PM   #6
Graham , North Carolina
It may be a bad ground. They will make a light look dimmer than the other
jerrypeterma is offline   Reply With Quote
Old 09-28-2008, 10:12 AM   #7
Des Moines , Iowa
Thanks to all for your ideas. At least we have something to go on now.
Old 11-27-2008, 01:22 PM   #8
2005 19' Safari
Cibolo , Texas
Curious if you ever found the cause. I have the same problem in my 2005 bambi and it's driving me nuts. THanks
Beaver is offline   Reply With Quote
Old 11-27-2008, 04:24 PM   #9
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
I too would look for a poor ground. Clean all grounds on both tail lights.
Also.. a good coating of Permatex Dielectric grease on ALL exterior bulb sockets and grounds isn't a bad idea.
"Any nation that can survive what we have lately in the way of government, is on the high road to permanent glory."
Molly Ivins
"Just because you don't know how, doesn't mean you canít."
Amanamus
"Never tow faster than your Guardian Angel can Fly"
Sweet Streams....🌥
Old 11-28-2008, 05:59 PM   #10
2005 19' Safari
Cibolo , Texas
Brake Light Problems
An update on my problem in my 2005 bambi in case someone else should encounter the same. Basically, the brake lights and turn signals were intermittent but the tail lights worked fine. Sometimes it would be the left only, sometimes both, and sometimes nothing would come on. Also, some of the LED's would not illuminate. I assumed it was a faulty ground as they all share the same ground that is under the bumper. Turns out it was the lights themselves. Took the lights out and checked them on a 12 V tester and sure enough they were all bad. Anyways, new lights work perfect but we'll see for how long. Still puzzled at what caused 4 lights to burn out. Power surge? Lightining? No idea.
Old 11-28-2008, 07:01 PM   #11
Des Moines , Iowa
In our case, the problem actually turned out to be on the truck side of the hitch.
Add an Exterior Door Light? biggoofball Lights - Interior & Exterior 12 09-07-2010 06:13 AM
Exterior Light Problem extiger Lights - Interior & Exterior 5 10-08-2007 04:55 AM
Overlander exterior light not working Mark&Bet Lights - Interior & Exterior 8 08-10-2006 01:29 PM
Source for exterior light, '92 Excella? EA Stein Lights - Interior & Exterior 9 01-29-2006 05:34 PM
Exterior Light??? balrgn Electrical - Systems, Generators, Batteries & Solar 26 12-14-2004 08:54 AM
