Old 10-27-2013, 12:04 PM   #1
2007 31' Classic
Kingston , ON
Exterior LED strip lights?
Has anyone tried to wire up adhesive waterproof exterior LED strip lights on their AS? I was thinking about tapping into the step light socket, and running (sticking on with adhesive) a 16ft (5m) strip of lights along the longitudinal central trim on the exterior door side. I found some waterproof strip light that draws about 5W per meter (so about 25W for the full length) and is not very expensive. I would probably try to augment the adhesive with some sort of mechanical clip as well.
paul
trvler is offline   Reply With Quote
Old 10-27-2013, 02:01 PM   #2
Becky B.'s Avatar
1964 17' Bambi II
Schererville , Indiana
Like this??:
Name:	Bill putting in LED lights.jpg
My husband installing the LED lights on a strip with a sticky back (which he also put gasket adhesive to keep it in place)
The finished light job.
I know someone else here put them around the outside of their trailer. My husband dedicated a wire to the lights when he put all the wiring in the trailer frame. I'm sure you could tie it in to the 12V lights.
Becky
1964 Bambi II
1988 Avion 32S
Becky B. is offline   Reply With Quote
Old 10-28-2013, 01:26 PM   #3
2007 31' Classic
Kingston , ON
I was thinking more about applying LED lights along the body for illumination ie as a replacement for the side light. But that looks pretty cool! Have you had any problems with the adhesive not holding on your travels?
Paul
Old 10-28-2013, 01:44 PM   #4
Becky B.'s Avatar
1964 17' Bambi II
Haven't gone on any long travels--only about 40 miles. I'm going on a pretty long trip soon & we'll see how they hold up! I know I saw someone on here with their lights around the beltline--it looked pretty cool.
Becky
1964 Bambi II
1988 Avion 32S
