Old 02-05-2015, 09:03 AM   #15
aquinob's Avatar
Portsmouth , Virginia
Cool. I picked up a 3 meter lenght of white LEDs from Amazon that came in yesterday, and this is pretty much what I want to do as well. Probably going to wait till a bit warmer weather too. I may wire it in with the light above the door or run it in separately, not sure yet. Your installation looks good.
Ongoing adventures at:
http://1973overlander.blogspot.com/
aquinob is offline   Reply With Quote
Old 02-05-2015, 08:06 PM   #16
TCwheels's Avatar
2011 20' Flying Cloud
Traverse City , Michigan
Originally Posted by Ktholin View Post
I finished installing strip lighting and very pleased with the results. I purchased a 15 meter strip of multicolored lights which fit our 16 foot awning perfectly. It can be cut at various lengths if need be. Together with the remote and controller total kit ran about $100.
I laid painters tape to mark a straight edge about 3 inches below the awning tube. I considered placing the strip on the inside aluminum strip of the roller, however the problem with this placement is the lights won't show if the awning is rolled up. This placement allows the lights to be seen with and without the awning out. The The LED strip is aluminum colored so it blends pretty well and is barely noticeable.
I ran the wires from the end of the strip up around the end of the roller tube on to the roof, under my solar panels and down along the bathroom vent tube and to the 12V fuse panel. Total installation took about 2.5 hours.
Below is a photo of the lights. The remote allows brightness control and color selection. There are programmed color sequences as well.
Attachment 231757
Attachment 231758
Looks great! Can you post the product info?
WBCCI #7246 Michigan Unit,Texas Hill Country Unit (associate member), AIR #91367
"Don't let perfect be the enemy of better."
TCwheels is offline   Reply With Quote
Old 02-05-2015, 09:05 PM   #17
z , North Carolina
Looks super sharp Ktholin. Please post the source! That really does look S H A R P.
FishinHatteras is offline   Reply With Quote
Old 02-06-2015, 09:19 AM   #18
Grey Goose
2011 25' FB Flying Cloud
San Clemente , California
I picked them up at a local RV supplier. I'll get the info when we return home in a few days.
Ktholin is offline   Reply With Quote
Old 02-06-2015, 09:40 AM   #19
Grey Goose
The LED kits can be found at www.rickstrailersupply.com. Go to the online store and type "LED strip" in the search box. I used a 16 foot color strip with controller and remote.
You may have to call them as the website has only limited info. (949) 498-2348 ask for Brian. Hope this helps. Let me know if you need more info.
Old 02-06-2015, 12:35 PM   #20
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
I have one of these kits from Amazon. It is the same kit that RV stores sell for $150.
Amazon.com: LEDwholesalers 16.4ft RGB Color Changing Kit with LED Flexible Strip, Controller with 44-button Remote and Power Supply, 2034RGB+3315+3215: Musical Instruments
MICHAEL
Old 02-06-2015, 12:38 PM   #21
2007 22' International CCD
Bump to follow
KE4GNK/AE
Old 02-06-2015, 01:13 PM   #22
AWCHIEF's Avatar
Images: 33
I posted the wrong link for the kit, this is the waterproof kit that I have, it can be wired either 12V or 120V.
Amazon.com: SUPERNIGHT® 16.4ft 5M Waterproof Flexible strip 300leds Color Changing RGB SMD5050 LED Light Strip Kit RGB 5M +44Key Remote+12V 5A Power Supply: Musical Instruments
MICHAEL
Old 02-06-2015, 04:11 PM   #23
Grey Goose
Originally Posted by AWCHIEF View Post
Probably similar. The remote is different. Importantly the power input is 100-240V. I used a 12v system. Price looks good.
Old 08-23-2017, 10:59 AM   #24
Luv Travel and Wine
2012 23' FB Flying Cloud
Dallas , Texas
KTHOLIN; Are you still happy with the LED light strip installation?
luv2trvl is offline   Reply With Quote
Exterior LED Strip Lights under Trailer RichHog Lights - Interior & Exterior 26 04-27-2014 09:01 PM
Exterior LED strip lights? trvler Lights - Interior & Exterior 3 10-28-2013 01:44 PM
Changing LED lighting to halogen lighting dreamstreem Electrical - Systems, Generators, Batteries & Solar 14 10-12-2011 06:42 AM
