Old 11-20-2010, 06:32 PM   #1
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
Exterior LED Retrofit for my '72 Sovereign
Spent the last week installing new LED running lights and LED tail lights. Last summer I installed LED backing lights but an elusive short in the backing light circuit prevented them from working.
I decided to find that elusive short today. First I found a loose bullet connector on the curbside light and fixed it, but I still had a short. After taking apart the umbilical/pigtail I found the culprit. A single strand of wire from the ground connection was touching the base of the backing light connector. After cleaning up this connection, I plugged the pigtail in again and Voila!! We've got lights!!!
Here's a few pics of all of the LEDs at dusk.
ID:	115632   Click image for larger version
1958 Overlander
2011 Wolf Creek 850N TC
2011 Ford F-250 Crewcab (6.2L), 3.73RE
WBCCI #5661/AIR #5661/TAC # AZ-6
4CU 1st VP
My '58 Overlander Restoration and Travel Blog:
http://mellomikesairstreams.blogspot.com/
mello mike is offline   Reply With Quote
Old 11-20-2010, 06:47 PM   #2
x
XXXX , XXXX
Mike here's a tip to avoid that happening at the 7 pin again. If you solder the end of each wire then there will be no stray strands to wander. Ther's an afwul lot of wires going into the small spot.
wasagachris is offline   Reply With Quote
Old 11-21-2010, 03:50 AM   #3
Ottawa , ON
Lookin' good, Mike! WTG finding the short.
Old 11-21-2010, 05:39 AM   #4
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
Good tip, Chris. Especially with the ground (and 12v charge line) wires being a heavier gauge (lots more wires).
1958 Overlander
4CU 1st VP
Old 11-21-2010, 06:16 AM   #5
Top
Always learning
Top's Avatar
1972 29' Ambassador
1962 19' Globetrotter
1951 21' Flying Cloud
Central , Texas
Images: 24
Send a message via Yahoo to Top
Those look great! I was just looking at them at the AS dealer near here. Nice work.
Lance
Top is offline   Reply With Quote
Old 11-21-2010, 07:11 AM   #6
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
Here's where I ordered my Running lights:
MDB series Double Bulls Eye Marker Lamp
I ordered the tail light and backing lights from Inland RV.
1958 Overlander
4CU 1st VP
Old 09-20-2012, 10:32 PM   #7
texasbound's Avatar
Bothell , Washington
mello,
Where did you order your LED backing and Tail lights?
Did you just replace the bulbs in the rest of them?
THanks,
Leo
-=TexasBound=-
1974 - 31' Airstream Sovereign Land Yacht "Dudley"
WBCCI # 7616
http://ismelltexas.wordpress.com
texasbound is offline   Reply With Quote
sovereign
LED lighting retrofit for interior lights Westfalia Lights - Interior & Exterior 372 12-17-2016 11:43 AM
'79 Sovereign 31 ft. Retrofit karlgrube Member Introductions 6 04-17-2012 12:50 PM
