Old 12-23-2016, 04:38 PM   #1
1976 31' Sovereign
Jacksonville , Florida
Exterior LED markers
I'm replacing my marker lights with LEDs. The originals were riveted and used that for the ground. The new ones have 2 wires (red and black). Black is ground. But look at the pics. How do I get a rivet tool to pull the shaft with such a distance to the head?
Name:   ImageUploadedByAirstream Forums1482536208.244620.jpg
Name:   ImageUploadedByAirstream Forums1482536230.548502.jpg
that's about 1/4" gap.
Andy Moreau is offline   Reply With Quote
Old 12-23-2016, 04:53 PM   #2
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Telluride , Colorado
Get a ferrule and use it as a spacer.
Should cost $.07 at Ace or mom and pop hardware stores.
Old 12-24-2016, 10:27 AM   #3
1976 31' Sovereign
My problem would then be that the shaft of the pop rivet would not be long enough for the rivet gun to grab.
Old 12-24-2016, 10:50 AM   #4
HowieE's Avatar
Princeton , New Jersey
Images: 12
Use sheet metal screws to mount the fixtures. You may have to remove the fixtures in the future for grounding issues so take the easy way out.
2004 Excursion 4x4
Old 12-24-2016, 11:18 AM   #5
eubank's Avatar
Airstream - Other
Bosque Farms , New Mexico
My inexpensive rivet gun has a bit of a nose on it so that it'll fit into somewhat tighter spaces. Kind of like this:
Lynn
ACI Big Red Number 21043
Changed markers to LED, now no power to Control Panel OilnH2o Electrical - Systems, Generators, Batteries & Solar 25 11-07-2015 10:14 AM
Replace double bullseye markers with teardrop. Sacrilege? Jamiep Lights - Interior & Exterior 3 09-17-2011 10:20 PM
Clipper, Hella LED, Design Line Hella, LED Kit, Stop/turn LED masseyfarm Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 1 12-15-2010 11:03 AM
LED replacements/markers davidz71 Lights - Interior & Exterior 7 04-15-2006 09:39 PM
