Old 07-08-2015, 12:50 PM   #1
2012 19' International
Shelby , North Carolina
Exterior LED lights flickering!
We have a 2012 19' Bambi Signature and have noticed that the exterior LED light over the door occasionally changes intensity, flickers and every now and them a section of the LEDs go out. A gentle tap brings them back on. Any experience with a situation like this? Could it simply be a loose connecting or is it a circuit board issue with the fixture itself? Thanks!
roger4147 is offline   Reply With Quote
Old 07-08-2015, 01:57 PM   #2
AnnArborBob's Avatar
2014 27' FB Eddie Bauer
Chelsea , Michigan
Images: 12
I've not had this problem with my particular unit, but it could be either of the issues you raised. I would take off the cover and see if the connections are solid. If you confirm that the connections are solid then I would say that you have a failing light bulb (or LED in this case.) Just replace it.
Good luck!
Bob Martel
WBCCI# 5766
Old 07-09-2015, 02:18 PM   #3
1968 24' Tradewind
1967 17' Caravel
Northborough , Massachusetts
If a tap seems to fix it then you have some kind of flaky connection. Most likely the bulb socket or loose wiring. I've seen soldered connections without any solder in them or cold solder joints where the solder did not wick into place.
A quick heat up with a standard soldering iron and some solder fixes these.
cwbiii is offline   Reply With Quote
Old 07-09-2015, 02:22 PM   #4
1968 24' Tradewind
1967 17' Caravel
Another issue can be a poor ground connection... many light fixtures on the Airstream use the shell as their ground return. The screws or rivets holding them in place can loosen up over time making for an iffy connection. Tighten the screw or replace the rivet to fix.
Old 07-10-2015, 03:18 PM   #5
2012 27' FB Eddie Bauer
Laguna Niguel , California
My porch light led does the same thing 2012 Edie Bauer I'll give it a tap and see what happens
TSOMMY is offline   Reply With Quote
Old 07-10-2015, 04:12 PM   #6
Sodbust's Avatar
1972 27' Overlander
Penokee , Kansas
Most new age light sockets,, depend on a mounting screw that holds the unit too the body as a ground path.. A little dirt,, or fuzz and the ground connection is broken..
If all your lights act this way its trying to ground into the hitch ball.. In that case it would require a close look at your trailer plug..
Sodbust
2012 Ram 1500 Tradesman Hemi, 4x4, 6 speed
20mpg empty, 14 mpg with 27' Overlander.
Today is the first day of the rest of your life!
Sodbust is offline   Reply With Quote
Flickering tail lights kimdrautz Lights - Interior & Exterior 2 09-09-2014 08:20 PM
flickering lights gkcs Electrical - Systems, Generators, Batteries & Solar 6 06-18-2013 05:17 PM
Freaky 12v lights flickering and fading out RichHog Batteries, Univolts, Converters & Inverters 15 12-13-2011 10:19 AM
Clipper, Hella LED, Design Line Hella, LED Kit, Stop/turn LED masseyfarm Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 1 12-15-2010 11:03 AM
