Old 09-02-2008, 04:21 PM   #1
safari25-05's Avatar
summerfield , Florida
exterior leaky clearance running lights..
I have an 05 safari FB with teardrop clearance lights. I was told by an airstream supplier that I have to buy the whole light assembly just to get the light gray color foam seal that the lens seals against on the mounting base. Over time where the lens sits on the seal, it crushes the foam, allows moisture to get in and condinsate on the inside of the lens. The lens has stamped data on it, ( SAE PC93 NANE 1235). Does anybody know who the manufacture might be, with a phone number? So that I may be able to buy just the seals only, yes I know they have new LED replacments lights. Thanks...
safari25-05 is offline   Reply With Quote
Old 09-02-2008, 06:13 PM   #2
SilverCottage's Avatar
2007 27' Safari FB SE
LONDON , ON
Go to any craft store or Walmart and get a sheet of the thin craft foam. Just trace the original seal with a ball point pen and cut them out with scissors. Kinda' like grade 1 all over again.
You will probably get 10 seals for about $1. You can even double up the seals if you wish. It worked for me.
SilverCottage is offline   Reply With Quote
Old 09-02-2008, 08:14 PM   #3
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
A couple alternatives for you. One is shower pan liner - by the linear foot at big box hardware. That's if the lights sit relatively tight against the skin. If you need something thicker get black pipe saddle gasket from the same place - it comes in squares you can probably get 4 gaskets per from. Both of these will last you for years. Cut the gasket with an exacto knife to the shape of the light body.
The problem you run into cutting gaskets for these is people (like me) will try to poke the screw thru the gasket or just pre-punch a small hole. That causes the gasket to pull away from the edge of the light when you install it. A paper punch can be used. Better is a rotating head leather punch - cheapest from Harbor Freight if you have one in the area. I looked everywhere for the gaskets - no one seems to sell them and Airstream was the only place I found even the lights that included them. Good luck...
Harbor Freight Tools
Old 09-02-2008, 08:16 PM   #4
Naples , Florida
Actually, your lights are probably leaking from the center screw, as there is nothing under the screw to make it water tight. You need to replace the screw (metric thread) with a stainless steel one, add the correct size SS washer, and then the appropriate size neoprene O-ring. This will stop the water leak. It usually IS NOT THE GASKET!
I have these components available, but they are in my shop in FL, and I won't be back there until 11-1-08.
lewster
Old 09-02-2008, 08:32 PM   #5
mustang's Avatar
1999 27' Safari
Kent , Ohio
I reccomend a small bead of clear silicone along the top of the light. I have seen this happen on many trailers not just Airstreams. Race trailers have the bead as the same color as the sides. If you can find silver silicone have at it. But I use a small bead of clear. No one ever knows. Just along the top side. not all the way around.
mustang is offline   Reply With Quote
Old 09-03-2008, 07:49 AM   #6
1973 29' Ambassador
Silicone doesn't like aluminum, it will look fine and be leaking. If you must, use Vulkem. Note that the bottom of these lights is open, to let water out, they are not really supposed to be sealed. Much better to properly seal the hole into the trailer, and let the lights be as designed
someisgood is offline   Reply With Quote
Old 09-03-2008, 09:10 AM   #7
Naples , Florida
On the newer trailers, it is the mounting screw that holds the lense to the base where water enters the light. I HAVE ONE......I KNOW! These are different lights than used on the earlier models. The simple and efective solution is placing an O-ring on the screw that holds on the lense, creating a tight water-proof seal.
Silicone is NEVER A SOLUTION to any sealing or leaking problems on any RV!!!
Use it at your own risk, as it WILL create problems for you in the near future. For sealing, use a high quality polyurethane sealant like SikaFlex 221. It bonds to anything, cures from moisture in the air, and is virtually bomb-proof.
lewster
Old 09-03-2008, 02:43 PM   #8
"Cloudsplitter"
Thumbs up Lew said it rite..
First, replace those screws with stainless, by the time the bulb needs replacement they very well may be corroded in place.
Second, an o-ring under the head, turn the gasket over, a little Permitex Dielectric grease on the base of the bulb, screw and around the base of the lens and don't overtighten.
Worked well for us.
Old 09-03-2008, 02:50 PM   #9
purman's Avatar
1968 28' Ambassador
Cedaredge , Colorado
Speaking of sealing Has anyone used "Geocel instant gutter seal" Even comes in Aluminum gray...
Jason
2008 5.7 L V8 Sequoia
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
Old 09-03-2008, 03:27 PM   #10
CanoeStream's Avatar
St. Cloud , Minnesota
Er... that's off topic. A search on the single word 'gutter' should return plenty of hits IIRC.
Lew's fix works very well! Take out one of the screws from the transparent cover and go to ACE hardware and have 'em match up the same diameter stainless metric screw. I couldn't find the same length -- got almost double the length and there is plenty of space inside the housing to accommodate that. ACE's O rings were extravagantly priced. I got my O rings from Home Depot. You may notice some light rust on the OEM screws -- that's because they are only nickel coated steel. You want the stainless. This is really a very east at-home fix.
5 meter Langford Nahanni
Old 09-03-2008, 03:31 PM   #11
SafariSS's Avatar
2005 30' Safari
Houston Texas , Texas
Or..
I had my trailer at Jackson Center last week and paid them to replace the 05 clearance lights with the new 08-up LEDs. They are cool because they do not have even a screw, I think the lens' pop on or something.
I have to vouch for the intensity as well, these things are BRIGHT./.
SafariSS is offline   Reply With Quote
Old 09-03-2008, 03:38 PM   #12
Silvertwinkie did his own LED marker light replacement. Don't know of a thread... Eric?
Old 09-03-2008, 05:28 PM   #13
2dabeach's Avatar
2007 25' Safari FB SE
North/East , New Jersey
Can you post a picture of the new LED clearance lights installed on your trailer?
2007 Safari 25' FBSE LS
2006 GMC Sierra 2500HD Crew Cab 4WD Duramax
2dabeach is offline   Reply With Quote
Old 09-03-2008, 06:09 PM   #14
"Cloudsplitter"
Bulb first.
Go to NAPA buy an LED replacement bulb, see if you like 'em.
Interesting to know how much JC is charging for this up-grade.
How much is just the assembly?
Old 09-05-2008, 05:19 PM   #15
"Cloudsplitter"
Thumbs up No tears in the teardrops
A method for sealing...
I removed the factory gasket. Cleaned the housing with body solvent. (Kent Acrosol) turned the gasket over, applied Permatex Black Weatherstrip Cement and stretched it slightly to fit under the lip of the housing.
Replaced mount screw with stainless machine screw, installed o-ring on the inside of lens.(keeps the screw from coming out when removed)
Apply Permatex Dielectric Grease to screw,O-ring and the edge of the lens. Easier to remove lens without damage to gasket.
Did this three seasons ago, no tears since.
Name:	SEALING THE TEARDROPS 001.jpg
ID:	66890   Click image for larger version
Name:	SEALING THE TEARDROPS 002.jpg
Name:	SEALING THE TEARDROPS 004.jpg
Old 01-27-2012, 10:59 AM   #16
"Cloudsplitter"
Thumbs up
An up-date.....Post 10 here.
Clearance Lights, What Color? Aerowood Lights - Interior & Exterior 7 06-13-2008 08:40 PM
Tail, running, clearance lights not working dufferin Lights - Interior & Exterior 14 07-09-2007 01:53 PM
Running marker / clearance lights unhooked Kistler Electrical - Systems, Generators, Batteries & Solar 19 12-18-2006 07:30 PM
Running Lights/Backup Lights 85 Sovereign GRAYMAN Lights - Interior & Exterior 7 08-10-2004 08:54 AM
Upper Identification Lights aka(Clearance Lights) pap Lights - Interior & Exterior 7 04-08-2003 06:14 PM
