Old 09-05-2008, 05:19 PM   #15
CLOUDSPLITTER "Tahawas"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up No tears in the teardrops
A method for sealing...
I removed the factory gasket. Cleaned the housing with body solvent. (Kent Acrosol) turned the gasket over, applied Permatex Black Weatherstrip Cement and stretched it slightly to fit under the lip of the housing.
Replaced mount screw with stainless machine screw, installed o-ring on the inside of lens.(keeps the screw from coming out when removed)
Apply Permatex Dielectric Grease to screw,O-ring and the edge of the lens. Easier to remove lens without damage to gasket.
Did this three seasons ago, no tears since.
Name:	SEALING THE TEARDROPS 001.jpg
ID:	66890   Click image for larger version
Name:	SEALING THE TEARDROPS 002.jpg
Name:	SEALING THE TEARDROPS 004.jpg
PFC
but Iím the Husband, so we went to Cleveland. 😂
RLC
Step aside Starbucks, this is a job for alcohol.
Old 01-27-2012, 10:59 AM   #16
Thumbs up
An up-date.....Post 10 here.
PFC
RLC
Clearance Lights, What Color? Aerowood Lights - Interior & Exterior 7 06-13-2008 08:40 PM
Tail, running, clearance lights not working dufferin Lights - Interior & Exterior 14 07-09-2007 01:53 PM
Running marker / clearance lights unhooked Kistler Electrical - Systems, Generators, Batteries & Solar 19 12-18-2006 07:30 PM
Running Lights/Backup Lights 85 Sovereign GRAYMAN Lights - Interior & Exterior 7 08-10-2004 08:54 AM
Upper Identification Lights aka(Clearance Lights) pap Lights - Interior & Exterior 7 04-08-2003 06:14 PM
