02-15-2012, 03:33 PM
1964 17' Bambi II
Edgewood
, New Mexico
Exterior Door Light
I have a exterior light next to my entry door. I disconnected this during my remodel and don't recall how it was connected to a power source. This light only has one wire for power and is grounded to the body. I think this single power wire went to the outlet the refrigerator plugs into, but I'm not sure. As you can tell, I'm not much of an electrician. Any help would be greatly appreciated.
Thanks, Gary
02-15-2012, 03:45 PM
1983 34' Excella
1967 24' Tradewind
Little Rock
, Arkansas
Thanks, Gary
I can practically guarantee you that the single power wire did not go to the outlet for the refrigerator. The outlet is 120volt AC, and the light is 12volt DC. Way Different! Dangerously so.
I suggest that you bring in someone with a better understanding of electricity.
Vaughan
02-15-2012, 03:51 PM
1965 22' Safari
Vassar
, Michigan
My 65 Safari's outside light is connected to light switch inside the trailer just above the window next to the door. You can see the switch above the window valance in the pic.
Tim
TAC MI 14
Everyday is a Saturday
02-15-2012, 03:52 PM
2019 27' Flying Cloud
Albuquerque
, New Mexico
Before you remodeled, you had a single wire that ran to the light switch. From the other side of the light switch you had a single wire that ran to your 12 volt fuse panel.
Ken L 2019 Flying Cloud 27FB
2020 GMC Sierra 1500 Crew Cab 6.2L Max Tow Four Corners Unit WBCCI #5783
02-15-2012, 04:01 PM
1964 17' Bambi II
Edgewood
, New Mexico
Vaughn,
Would this possibly connect to the light that mounts under the overhead cabinet that provides light for the sink and cooktop? I'm sure this is 12volt DC. I have re-wired this light and it's working fine. This light has two wires.
Thanks, Gary
02-15-2012, 04:07 PM
1964 17' Bambi II
Edgewood
, New Mexico
Ken,
My outside light has the switch under the lens (outside). This was installed by the previous owner, so the one wire provides power.
Thanks, Gary
02-15-2012, 07:28 PM
1983 34' Excella
1967 24' Tradewind
Little Rock
, Arkansas
Vaughn,
Thanks, Gary
Much better!
Hook to the hot side and you should be good.
Vaughan
02-15-2012, 08:38 PM
1964 17' Bambi II
Edgewood
, New Mexico
Thanks to all for your help.
Gary
