Old 06-17-2009, 09:25 PM   #1
1973 31' Excella 500
Concord , New Hampshire
Excella Fluorescent Light Mystery
I have a 1973 31' Excella 500. There are fluorescent lights in the troughs above the curtain tracks in the front lounge. I can't find ANY mention of them in either the owners manual or the service manual.
Now for the question.... Does anybody know where the switch is to turn them on!!!! :-) I have looked and looked and can't for the life of me figure out where it is.
jjfitzy is offline   Reply With Quote
Old 06-17-2009, 10:00 PM   #2
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
They are an addition from a PO. We have the same (120 volt) fluorescents in the same spots. The switches may be on the ends of the fixtures.
Old 06-18-2009, 12:46 AM   #3
That was standard for your Excella.
I will not be back in my office until 6-22, and I will search for the info for you. I have that info in one of my books.
Old 06-18-2009, 05:25 AM   #4
Excella Lights
Hmmmmm, they really do look like they are factory installed... The 1975 owner's manual lists the fluorescent bulbs in the buld replacement section, but the 75 service manual doesn't show ANY 120V light fixtures either. ( I'm using both the 73 and 75 manuals, since the 73 manual doesn't even show a floorplan matching my Excella! ) The end caps of the troughs look original and have no switches.
I'm chasing some other wiring problems at the moment, so I have the center roof section removed. Maybe I'll take one of the curtain trays off and see if I can trace the wiring.
Thanks for your help.
Old 06-18-2009, 05:40 AM   #5
GStephens
GStephens's Avatar
1982 31' Limited
1953 25' Cruiser
Hamilton , Texas
Look behind the front curtain next to the street side couch arm. There should be both an electrical outlet there and the switch for the florescent light fixtures over the windows.
GStephens
GStephens is offline   Reply With Quote
Old 06-18-2009, 06:21 AM   #6
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
GStephens
That's where the switch in my 1983 Excella is. There is another electrical outlet, but no switch, on the curb side.
Oh, just because you have them and a switch doesen't necessarily mean that they are working. Mine didn't. I have Cold Cathode Fluorescents (CCFL) over the street side, but don't like the color of light. I plan to get three matching fluorescents that I can fit with warm white tubes.
Vaughan
Old 06-18-2009, 06:49 AM   #7
By the way, those flourescent light fixtures are 12 volts DC.
Old 06-18-2009, 07:11 AM   #8
Silverhobby's Avatar
1967 26' Overlander
1968 30' Sovereign
Mosheim , Tennessee
Aren't the light fixtures 120 volt bulbs, with a step down transformer? That is how my thin lites operate.
//------AIR # 7303------\\
WBCCI 17109
visit my restoration blog at:
Old 06-18-2009, 07:18 AM   #9
Well Preserved
1993 21' Sovereign
I forget the voltage fluorescent tubes operate at, but it is significantly more than 120 volts. The high voltage excites the gas in the tube, causing it to glow.
Old 06-18-2009, 07:26 AM   #10
The 12 volts DC, is electronically "chopped" to create AC, then the transformer "steps up" the voltage to a higher AC voltage so that the bulbs will work.
Transformers don't work on DC.
Usually, the electronic circuit board goes bad. Years ago replacement boards were available, but I think they are gone.
The easiest fix, is to replace the entire fixture.
You may have to be a little creative to make them fit within the drape valance.
Old 06-18-2009, 07:58 AM   #11
1983 34' Excella
1967 24' Tradewind
Images: 32
Andy is right. Replacement is the way to go!
They are very strange fixtures. Same for those around the ceiling vents. Odd tube size that is difficult to find and only seem to exist in cool white, even searching online. Interestingly enough, I found remnants of Thin Lite labels on some of them.
I will post photos of the one remaining label on my ceiling vent fixtures soon. I am replacing that vent in the bedroom with a FanTastic Vent this weekend. I'll look for the remaining, not functioning, Thin Lite over the windows at the same time. One had been replaced with a fixture from Maple Light that I like a lot. It still works fine, but I can't find anything about it. I would like to have some more, but they are apparently no more.
Vaughan
Old 06-18-2009, 01:41 PM   #12
First off, thanks to everyone for their input, it has been extremely helpful.
But the mystery deepens, these bulbs are F15T8-CW, which I believe are AC lights. At least they are the same as the ones in the mirrir fixture in the bathroom of my house! Still haven't found a switch, yet though. Nothing near the outlet on the street side end of the couch.
There is what looks like a replacement plate on the curbside underneath the AC outlet there, and next to the porch lite switch. I had assumed it was covering where the antenna rotate controls were originaly, but perhaps that is an errroneous assumption. I will drill out the rivets on the plate and see what's behind there tonight. I know it's an afterthought plate, because the rivets are aluminum colored and not white like the rest of the original rivets.
Joe
Old 06-18-2009, 02:08 PM   #13
1972 29' Ambassador
Harrah , Oklahoma
Joe
They should be 12v lights, because you want light when you're running on battery, right?
Perhaps the PO put in the wrong bulbs, or the fixture died and they replaced and rewired for AC lights. Regardless, tracking down the weird things in an old airstream is part of the fun.
Just last week I learned I had a laundry hamper hidden behind the toilet.
My Brain Project and Tech Notes
airbassador is offline   Reply With Quote
Old 06-18-2009, 02:26 PM   #14
richinny's Avatar
2011 34' Classic
the bulbs are the same but the ballasts are either 12vDC or 120vAC.
Ricky
'89 Excella 25 mystery switch? Pix attached also... BillTex 1987 - 1989 Excella 12 05-22-2011 01:05 PM
another mystery light dilemma wannaroam Lights - Interior & Exterior 97 09-14-2008 05:36 PM
Mystery light on 1982 280 Excella Dash jisom12 Classic Motorhomes 9 09-14-2008 02:33 PM
"Dim" fluorescent light in bathroom and etc. Kistler General Interior Topics 4 10-24-2004 03:24 PM
Incandescent VS Fluorescent upallnight Electrical - Systems, Generators, Batteries & Solar 3 06-17-2004 07:57 PM
