Old 09-01-2011, 06:27 PM   #15
Alumaholic's Avatar
1966 24' Tradewind
Albuquerque , New Mexico
Images: 33
Ground Is Key to Your Riddle
If you can't see your grounding wire running to the tongue, it may have been removed by some PO who didn't realize its importance. Others will chime in who know your particular Airstream, but there should be a heavy grounding wire running from a bus at your inverter to the frame of your trailer somewhere on the A-frame near the tongue.
As I mentioned yesterday you must repair or restore your ground before you do anything else.
For obvious reasons, we don't rely solely on the tow vehicles ground.
ALthough we can spot those who do by the dim, flickering running lights.
Ken L
1966 Tradewind 24
2007Chevy Silverado 2500 HD Duramax/Allison
Four Corners Unit WBCCI #8654
Alumaholic is offline   Reply With Quote
Old 09-07-2011, 08:16 AM   #16
goshawks00's Avatar
1966 22' Safari
1954 22' Flying Cloud
Saline , Michigan
As I said all is working well, nice and bright!! Thank you all. Now a follow up... I am replacing all the upper running lights along the top of the trailer. The originals are kind of ...well... original and old. Gaskets are shot, the ground through the rivets bad... so new base units are coming,today hopefully... and I was told I can keep the original lenses which is great!
Now then I am not sure if the bases will come with bulbs and I suspect they won't, so I will most likely need new bulbs for them. What is the proper bulb number for them? Please no I am not interested in installing L.E.D. bulbs, just vintage original types thank you.
Barry & Karen in Mi.
goshawks00 is offline   Reply With Quote
Our '56 Safari (aka Our Retirement Home) SafariSteve 1956 Safari 41 09-04-2013 05:55 PM
Electrical issues with clearance lights 1987_345 Classic Motorhomes 13 08-25-2011 08:13 AM
1968 Safari 22' :: 1968 Airstream Safari Darrengj Airstream Registry Discussions 0 08-19-2011 08:32 AM
Safari :: 2006 Airstream Safari SE Mrs Silverback Airstream Registry Discussions 0 08-19-2011 08:31 AM
'62 Safari electrical update questions Peggy Wilson Electrical - Systems, Generators, Batteries & Solar 3 02-12-2011 07:23 PM
