Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar > Lights - Interior & Exterior
Old 07-19-2009, 08:13 AM   #1
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
Electrical & Radio Interference Questions
Just finished reworking the trunk area (what a bear of a place to work in) and now moving into the bumper storage area.
1. I need to unhook the main ground wire to paint the frame. Running a line to it and out to a ground stake next to the trailer. Any problem with that.... Also.....
2. My overhead lights are on the blue circuit that also feeds the radio and control panel. The more lights you turn on the more buzz the stereo picks up. I took all the light switches apart and cleaned them - that helped some. Any ideas.....
Thanks....
Old 07-19-2009, 08:20 AM   #2
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
Sounds like a noise filter may do the trick. Check out this link. The principles they outline apply to any 12v radio system.
Noise Suppression Guide
1958 Overlander
2011 Wolf Creek 850N TC
4CU 1st VP
mello mike is offline   Reply With Quote
Old 07-19-2009, 08:27 AM   #3
Mikethefixit's Avatar
1977 27' Overlander
Trotwood , Ohio
Send a message via Yahoo to Mikethefixit
Gary
I have the same problem only its with the am side of the radio. The filter caps (capacitors) are bad in the Univolt. I have yet to see anyone post a schematic of a Univolt or I would have pulled and rebuilt mine already.
I really have never even seen who the manufacturer of the UNIVOLT was.
Roger & MaryLou
___________________
F350 CREWCAB SW LONG BED
7.3 liter Power Stroke Diesel
1977 27ft OVERLANDER
KA8LMQ
AIR # 22336 TAC- OH-7
May your roads be straight and smooth and may you always have a tailwind!
Mikethefixit is offline   Reply With Quote
Old 07-19-2009, 08:48 AM   #4
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
One problem already I see (from the article Mello Mike posted) is that the original antenna does not have a ground wire - the new replacement ones we just found do.
Not sure I want to try feeding the new cable but that may be necessary.
I'm not sure what converter I have - can't see the label. It's not the big metal box Univolt but may just be a newer version. It's black plastic housing with slightly inward sloping sides toward the top. The fuse panel has been moved out on it's own where the Univolt apparently had the fuse panel inside. It does still hummmm like a Univolt. The Power On indicator light on the panel does not work which I think is an indicator of a replaced converter...?
some more electrical questions bullydogsmom Electrical - Systems, Generators, Batteries & Solar 2 04-11-2009 06:28 PM
Several electrical questions awayhome Electrical - Systems, Generators, Batteries & Solar 9 12-22-2008 07:22 PM
General Electrical questions LHall Batteries, Univolts, Converters & Inverters 7 08-07-2007 12:41 PM
Hitch Interference Camp-Dog Hitches, Couplers & Balls 14 12-13-2004 03:56 PM
Installing an Inteli-power & other electrical questions Towster Electrical - Systems, Generators, Batteries & Solar 7 08-07-2003 05:04 PM
