Old 06-07-2017, 10:07 PM   #1
3rd one is the charm?
pcskier's Avatar
2014 23' Flying Cloud
Park City , Utah
Easy Fix for warming up those bright LED lights
I actually picked up this idea somewhere a year and a half ago, maybe here on the forums or somewhere else...in any case, to the OP, if you're out there, thanks. I finally got around to it a month and a half ago. This was an easy $7 modification that changed my evenings and nights!
I couldn't stand the color of the LED lighting in my 2104 FC...even with the dimmer at lowest setting the color was just too bright and blueish for me. Rather than replace all the lights with 'warmer' LED's, which would cost a few bucks, I instead used theater lighting gel sheet, which is just a thin sheet of colored plastic, which is available in all kinds of colors/tints. Below is the link for what I used.
I removed the lens from each ceiling puck, and using the glass lens as a template, use an exacto knife to cut round circles of gel. You could just use scissors but the knife was easy. Then I installed two pieces (one wasn't enough for my taste) on the inside of the glass. There are little tabs that hold the glass in place, I slid the edge of the gel pieces under there just to help hold them flat.
The difference was AMAZING. The interior of the coach went from harsh, bluish white, to a warm, incandescent color. Plenty bright for general lighting, and really nice for ambient if the dimmer is engaged.
In the bedroom of my FC 23 FB, I actually used 3 sheets in each lens, to make it even less bright in there on the low dim setting.
For the larger lights over the kitchen sink and dinette, I cut sheets to fit the inside of the plastic lens housings, and used some craft tacky spray to secure the film to the inside of the plastic lens.
Super happy with how it turned out, as I am picky about lighting and can't stand harsh, bright light. Even the cabinetry in the Flying Cloud looks so much nicer and warmer. Not to mention people!
The LED lights generate so little heat, there is no issue with the gel heating up and melting or burning. I've had mine in for a few trips and they are working great with no issues.
One roll was enough to do 2 layers in all my main area pucks and 3 layers in the four bedroom pucks, as well as one layer in the kitchen, dinette, and bathroom fixtures.
https://www.bhphotovideo.com/bnh/con...m=Y&sku=166181
pcskier is offline   Reply With Quote
Old 06-07-2017, 10:27 PM   #2
CruizinDux's Avatar
Tracktown USA , Oregon
pcskier interesting tip. Just to confirm you used orange as in the link? I'm color blind and would be interested in hearing how or why you settled on orange.
CruizinDux is offline   Reply With Quote
Old 06-07-2017, 10:28 PM   #3
CruizinDux's Avatar
Old 06-07-2017, 10:34 PM   #4
pcskier's Avatar
Park City , Utah
Yes Bob I used the film that I linked to. Resulted in a very pleasant warm light.
I think I had run across it on a blog somewhere, so that's why I tried it. I've read of some other colors people have used. It might be possible even to use a darker tint so as not using 2 layers like I did, but this tint allows you to try one layer, and if you want more warmth/tint, add another. Or even three layers, which I did in the bedroom area. I did leave my two reading lamps in the bedroom alone because I can't figure out how to remove the lens from those.
Old 06-07-2017, 10:43 PM   #5
2013 25' International
Boise , Idaho
Thanks!
Couldn't agree more that the LED's cool tones are just not comfy. My Serenity has a few paper shade lamps and it helps, but this is a great idea, thanks for sharing!
-Adam
afk314 is offline   Reply With Quote
Old 06-07-2017, 11:13 PM   #6
CruizinDux's Avatar
pcskier, many thanks. Orange...go figure. My wife has commented on the lights many times and she is also in charge of things with a color. I'm thinking I'll pass this on to her.
p.s. my apologies for the dupe post. It seemed to stall on the load so I backed out and re-posted. oooops.
Old 06-07-2017, 11:23 PM   #7
pcskier's Avatar
Park City , Utah
It sounds odd but believe me she will love it if she is looking for more of an incandescent look. I was amazed and very happy with it, and for under $10, it was a no-brainer.
Old 06-07-2017, 11:54 PM   #8
SuperTrouper's Avatar
2008 27' International FB
Petaluma , California
Yup. That's the right stuff. You can add diffusion to remove the refraction of the leds as well. The warm LEDs I ordered online were the right color temp (3600K) but the bumps in the puck lamp lenses exacerbated green lines from the led segment edges. Made people look kinda sick. So I added frost diffusion using the same method, placing in the puck lens. https://www.bhphotovideo.com/c/produ...ter.html<br />
SuperTrouper is offline   Reply With Quote
Old 06-08-2017, 12:08 AM   #9
pcskier's Avatar
Park City , Utah
Originally Posted by SuperTrouper View Post
Yup. That's the right stuff. You can add diffusion to remove the refraction of the leds as well. The warm LEDs I ordered online were the right color temp (3600K) but the bumps in the puck lamp lenses exacerbated green lines from the led segment edges. Made people look kinda sick. So I added frost diffusion using the same method, placing in the puck lens. https://www.bhphotovideo.com/c/product/166135-REG/Gam_GC10_20x24_GamFusion_10_Filter.html
Good to know for those with those type of lenses in the pucks. In my 2014, the lenses are 'smooth and clear' for lack of a better description...no refractive edges on the lens.
I was in a friend's 2007 last week and noticed that their lenses had the refractive pattern that you're describing.
Old 06-08-2017, 05:36 AM   #10
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
Pcskier - thanks for sharing. Could you post some pics of what it looks like inside your trailer with the lights on? Just curious to see what the difference is. I have a 2012 and the LEDs are sort of "hospital" like...
SteveSueMac is online now   Reply With Quote
Old 06-08-2017, 12:23 PM   #11
2019 25' International
Washington , Washington, D.C.
I hope the Airstream folks at the factory are following this and perhaps offer buyers options about type of LEDs they want in their Airstreams. I plan to buy a 25' Serenity this year and it would be nice if the lighting was, well, uh, serene - as in a warm, incandescent sort of way.
PatLee is offline   Reply With Quote
Old 06-08-2017, 12:55 PM   #12
abqdor's Avatar
2016 25' Flying Cloud
Albuquerque , New Mexico
This is an earlier thread on the topic along with pictures I posted of the gels and how to install. Really helped get away from that Walmart lighting look.
https://www.airforums.com/forums/f37...ml#post1862490
'17 Ford F-150 Ecoboost, max tow package
'13 GMC Yukon Denali 6.2L V8
'04 GMC Yukon SLT 5.3L V8
abqdor is offline   Reply With Quote
Old 06-08-2017, 01:00 PM   #13
pcskier's Avatar
Park City , Utah
See the post a couple more down from abqdor and follow their link...they have a pic. Mine's in storage at the moment. I should have taken before and after pics. But believe me, the difference is dramatic!
Old 06-09-2017, 01:31 AM   #14
gecko's Avatar
2009 28' International
Pacific Palisades , California
Hi-yes, a great way to go. We posted here when we did the same back in 2010-2011 to our new 2009 Ocean Breeze 28. Another way to cut is to buy a "compass" from an art supply store..You use the sharo pointed end to Lin down the sheet of lens filter, and the exacting mounted on the end of the other arm to cut out the circles.
gecko is offline   Reply With Quote
Old 06-09-2017, 10:33 AM   #15
2006 28' Safari SE
Seattle , Washington
Thank you!
Thank you so much for this post!! I've ordered the film and can't wait to simply and inexpensively transform the lighting in my 2016 FC!!!
Pjoh is offline   Reply With Quote
Old 07-01-2017, 08:40 AM   #16
Traveler
TravlinMan's Avatar
2017 25' International
Staunton , Virginia
I did this and it is excellent. Boy I sure hated those icy blue lights... Now they're nice and warm and I can actually turn em on without cursin.
Thanks, y'all!
TravlinMan is offline   Reply With Quote
Old 07-01-2017, 08:50 AM   #17
Traveler
TravlinMan's Avatar
Staunton , Virginia
Worst thing about these trailers is that awful blue lighting. I almost cried the first time I turned em on. I never once used the bedroom lights til I fixed em with the gels. Instant headache. Still haven't figure out how to replace this 'readin light' in the bedroom. The bulb sticks out so ya can't gel it. I just use it to hang stuff from cause turnin it on makes me weep. I wanna switch it with somethin warm.
Good news is the serenity has two warm lights at the dinette. I only used those til I geled the rest.
Also to turn on the hallway light by the bathroom and shower, ya gotta go all the way to the entry of the trailer and turn on all of the kitchen lights. 8 lights in 2 rooms controlled by just one switch.
Airstream clearly don't know much about lighting.
Old 07-22-2017, 09:14 PM   #18
Hi there, can anyone tell me how to get the puck light in the dining room table off.
mjsully is offline   Reply With Quote
Old 01-23-2018, 05:23 PM   #19
2018 19' Flying Cloud
Coeur d Alene , Idaho
I just added the film to our 2018 Bambi. Probably the best thing I've done for her yet. Here are before and after pictures.....
Name:	LED Before.jpg
ID:	302877   Click image for larger version
Name:	LED After.jpg
Dale & Jane
2018 Flying Cloud 19
2003 Dodge Ram 2500 Quad Cab Diesel
KelloggKid is offline   Reply With Quote
Old 01-24-2018, 07:17 AM   #20
Wow, what a difference. From hospital cold to warm and comfy.
How EASY to break into Airstream? TOO EASY Foiled Again Doors & Locks 24 09-18-2019 09:12 AM
Rear reading lights too bright? jacobo1 Sprinter and B-van Forum 22 11-06-2018 11:32 AM
bright lights relay dieselblimp Classic Motorhomes 4 05-26-2016 10:59 PM
Clipper, Hella LED, Design Line Hella, LED Kit, Stop/turn LED masseyfarm Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 1 12-15-2010 12:03 PM
