Old 08-27-2018, 07:35 PM   #41
turk123's Avatar
2019 30' Classic
Canfield , Ohio
Her is my wife making many many circles!
PNTA 807 material.
First one who PM's me, I will send you ten in the mail for free!!
Don't forget your address!
Name:	Disks lamp 1.jpg
x\x/x\x/x\x/x\x/x\x/x\x/x\x/x\x/x\x/x\x/x\x/x\x/x
2017 Airstream International Signature 27FB Twin
2019 Airstream Classic 30 Twin
Our Google images and chat: https://photos.app.goo.gl/CMQbpNXQwapMnj8t9
turk123 is offline   Reply With Quote
Old 08-27-2018, 09:47 PM   #42
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
PNTA 807 material.
I wish I had seen that before I cut all those roughly-circular blotches of filter gel. Freehand with scissors. Looks fine in the end, though. 17 in my trailer, not counting the sink and bathroom lights.
— David
Old 08-28-2018, 05:37 PM   #43
turk123's Avatar
2019 30' Classic
Canfield , Ohio
Contest over! We actually have two winners.
My wife is going to cut the rest of the material and I will see how many are left. Pm me to be the third winner if we have enough.
Old 08-28-2018, 07:39 PM   #44
D44
D44's Avatar
2017 25' Flying Cloud
Lawn Guyland , New York
Originally Posted by moosetags View Post
Thanks for the tips on removing the lenses. I cut the material with a Fiskars circle cutter. It worked great.
The film that I used was from B&H. It is their stock number GA1543S. It really makes a difference.
Brian
Can I get a reference for the Fiskars Circle Cutter?
Walt
WBCCI - 29375
D44 is offline   Reply With Quote
Old 08-28-2018, 09:55 PM   #45
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
I got the Fiskars Circle Cutter on Amazon. It cuts from 1" to 8" diameter circles.
Brian
SuEllyn & Brian McCabe
2018 Silverado 2500 (Lillian)
Old 08-30-2018, 07:32 AM   #46
D44
D44's Avatar
Easy Fix for warming up those bright LED lights
Thank you - should have thought of that myself. Ordered.
Walt
WBCCI - 29375
Old 09-30-2018, 01:42 PM   #47
Me too!
mjsully is offline   Reply With Quote
Old 10-15-2019, 07:03 PM   #48
2016 27' International
Anacortes , Washington
Like so many others have said those bluish LED lights are horrible (in our 2017 27’ AS). I finally got around to buying the gel sheets “pcskier” bought, and just finished installing them all. I tried one layer, than two to see what we liked. We settled on one layer as two seemed a little too orangish.
I have a circle template from past drafting use, and office stores likely have them. The circle measured for the lights was about 1-⅞” diameter. My template was either 1-Ύ” or 2”. I used a sharpie and the 1-Ύ” size, and then scissors to roughly cut outside the sharpie line. All fit fine.
Next up was how to remove the light lens. I tried a few dental picks, did not work, then eventually a box/utility knife-bingo. I soon learned, without any mistakes, just insert the tip between the inner and outer rings, then wiggle it while pushing in a little harder. Sort of like shucking an oyster! Another tip- use a sharp sharpie to make a small ref mark on the two rings as otherwise one has to try to find the alignment necessary to seat the rings. Marks can easily be erased with lighter fluid (naphtha).
I also wanted to tackle the two wall scounce shades to tone those down. I cut the gel into a rectangular piece, something like 4” wide by 14” or something so the gel fills the inside of the shade. No need to glue or anything else. I love the orangish shades, much better than the harsh white.
Like others have said, the difference is amazing. One sheet of gel was plenty for our 1 layer. I will use gel on the outside door overhead light to tame that overly harsh light. Maybe two layere for that, will see.
I am replacing the LED light strip running along the underside of the awning too. Easy to do using the stick-on LED flexible tape. I am happy with using Superbrightleds.com products. I bought their waterproof 2700K 16’ spool and it came with connectors on both ends. I will wait until spring for install when the aluminum is warm to achieve better adhesion. Excited to see how much better that looks than what AS installed.
Pat Pierce is offline   Reply With Quote
How EASY to break into Airstream? TOO EASY Foiled Again Doors & Locks 24 09-18-2019 09:12 AM
Rear reading lights too bright? jacobo1 Sprinter and B-van Forum 22 11-06-2018 11:32 AM
bright lights relay dieselblimp Classic Motorhomes 4 05-26-2016 10:59 PM
Clipper, Hella LED, Design Line Hella, LED Kit, Stop/turn LED masseyfarm Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 1 12-15-2010 12:03 PM
